Vert top sloppy
Old Aug 10, 2008 | 10:30 PM
betyelou's Avatar
betyelou
Default Vert top sloppy
Have noticed that my 96 CE vert top is not as tight as it used to be. Is there anything you can do to tighten them up. It appears to have streched and is sagging.
Old Aug 10, 2008 | 11:56 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default top
Its stretched. You may be able to put some type of a long flat bow of wood along the bows. Its a vette though. Buy a new top and install it. The results will be what you are looking for. Its an easy process to replace. Its time consuming and requires patience. You can do it start to finish in one day. I have put 3 tops on my 89 since I bought it new.
Or buy a hard top that bolts right on.
Good luck
Corvette Mike
Old Aug 12, 2008 | 08:05 PM
trulytex's Avatar
trulytex
The best way to cure sloppy & stretched out is to replace with new. It is usually expensive but worth it. It works for Convertible Tops Too......
To Vert top sloppy
