I have owned a c3, c5 and c6. I am now considering a '96 LT4 with 60-70K miles on it.
To those in the know, please give me your thoughts on this model year. Do they require a lot of attention, or are they reliable if one treats them well?
At this mileage range, what maintenance may be needed in the future? Can the passagner airbag be turned off?
Finally, what is the vehicle worth in good condition?
From: SCMR Rat Pack'r Charter Member..Great Bend KS
ALL the maintenance will be required in the future.
The '96 is among the most reliable C4's.
The airbags can be disabled, but not "turned off".
What's an unknown C4 worth? It's worth from zero to about $30,000, depending. Sorry, that's the best I can do.
I have no experience with the 96, so I'll just parrot what I've read, and give you my opinion.
The 96 is the best C4. Most of the bugs ironed out. It's still relatively young at 13 years old. LT4 is the way to go.
If I could sell my car, I'd buy a 96 LT4. Lots of pull, will run with an early C5 and if something like the trans goes, it's much less expensive to fix. I'd expect to pay around $15k for a good 96 LT4.
Cheaper isn't always better, if or when I buy another C4, I'll spend the extra to get a good car.
Larry
__________
not easily impressed....
Larry, is disabling the airbag just a matter of pulling a fuse? Also, how far (or miles) into the future should one expect to begin to maintain or replace parts?
I bought my LT4 with 70k miles last November for $15k, and am glad I did! It's a great car. Like all cars (especially Vettes) they have their quirks, but it's been my reliable DD ever since. I've had to do some maintenance, but nothing that I couldn't do myself, or that has kept it off the road.
As far as the airbags go, I think someone sells a kit to turn it off. I'll go scour the internet, but I think there's a tech article on Corvette Magazine's website on the installation.
Just spoke with the owner of the prospective vehicle. He's seems to be a very stand-up guy. He informed me, in depth, on the car and its history.
The only two things he mentioned that might be of concern are:
1) a couple of drops of oil behind the balancer from time to time. Anyone have ideas on the possible sources of this problem?
2) when backing up the car about 20' or so, there is a "clunk" sound coming from what he believes are the breaks. As he understands it, this is not uncommon and somewhat typical of model? He's built and modified cars before and doesn't consider the sound an issue. Opinions?
My opinion: do it!
Thanks. Minor maintenance is ok, I just don't want any large expenses. I'll probably make the purchase. Just doing some homework first.
You want reliable buy a new vette. A 96 will leave you stranded on the side of the road, but may be that is your destany. Your out of cell phone range you walk to a little dinner and you end up meeting a hot waitress and spend the night at a motel 6.
Possibly the crank seal or WP/Optispark drive seals.
That sound might be the ABS doing its self-test, triggered upon reaching 3-4MPH after each startup. I would describe the sound as equal parts "groan" & "clunks", and it can sometimes be disconcerting even after you are accustomed to it. The pump is located in the compartment behind the driver's seat. If you rule that out, then there is an issue.
Do yourself a favor and go through the records well before purchasing anyway. The guy I bought from was also a stand up guy and forthcoming in answering questeions, but it was only once I was organizing mine afterward that I noticed a couple years of history missing from the first owners, and that one reciept noted that he had run the car into a curb. That's my mistake, not necessarily his. It came out no worse for wear though, and has been great for me the last 5 years.
Look for or ask whether the water pump & optispark have been replaced - lots of folks here will opine that the originals would be due to fail soon, but I wouldn't worry about it on a car that has been taken care of. It's nice to know either way.
I have had a C1, & a C2, & a C3, & an LT4. The 96 LT4 is by far the fastest, most quiet, most reliable, dryest inside, most economical of the three. Go and buy it for Pete's sake!!! I am 6' 7'' and I am comfortable once I'm in it. Getting in and out is challenging, but not impossible.
The oil leak could be from the opti or crank seals as mentioned above, or could be from the crankshaft position sensor o-ring, or from the front of the intake manifold. Oil leaks at the front and rear of the intake on LTx engines are very common - I discovered that the bolts weren't torqued properly at the ends of mine, and tightening them seemed to solve my small leak for now.
A common problem with '96 models is with the air conditioning. Make sure the A/C blows properly from the dash vents, rather than through the defroster and floor outlets. There are a bajillion threads on that subject here, and the fix isn't necessarily expensive (though a bit of a PITA), but if you find this problem on the car you're looking at, you might be able to use that as a bargaining chip.
Here's some great info about what to look for on C4's in general:
I bought two 1996s, one with 31k at the time for $16,000 and the other has 114k miles for $8000.00. Sometimes you pay alittle extra for lower miles. You can find a real good deal and they are great cars.
I love my '96 but if I was going to do it over again I would get an LT4. Unless special ordered they are the only 6 speed '96's. I got mine in Nov last year and have enjoyed ever minute of it. The guy I got mine from seemed to be up and up to so I took his word on a lot of things I shouldn't have. One was a leak in the front just like yours has. It cost me 1100.00 to fix that leak. Opti of course. The heater vent control valve is notorious for going bad on the '96's. Not difficult to repair it's just a PITA to get to. It's under the dash on the drivers side firewall. Some have had problems with the VATS on this year. I've been fortunate there so far. The Bose stereo is really not that good. The CD part of it is almost a given to failure. The whole car is an electronic nightmare if introduced to to much water. There's a sensor for everything. So be careful there! All in all it's a great car and very solid. It's really quiet inside with no rattles. It's considered the best C4. Good luck with your decision.
Nuttin against a good LT4, But! For little (if any) more, you can have the ZR-1 which will put ya on another level all together. As always, low mileage and newest models are usually the better cars. But, the LT5 is bullet proof and there is one heck of a support group to help you with anything you might need!
Don't take my word tho. Go drive a Z and you be the judge! (heh, heh, heh...) I did, and I never looked back!
I've put 45,000 miles on my '96. It's been a great car. Just yesterday I threw it down the entrance ramp edging 6k on each shift leaving the crowd behind only to purr through the Corsas at the light as always. It's the last of the C4 with the last true small block derived from the '55 model.
It has the best heater and AC (manual) of any car ever owned. Although it's worth only 12 or 13 thou 81,000 miles, it's my baby. A great therapy to maintain and upgrade. It'll pay you back many fold in enjoyment. Go get it!
Larry, is disabling the airbag just a matter of pulling a fuse? Also, how far (or miles) into the future should one expect to begin to maintain or replace parts? Brannon
You'll need to cut some wires to reliably disable the airbags. After that, you have to splice in a certain resister to those wires to stop the "AIRBAG" light from displaying in the DIC. (I had to do this when I put in a MOMO steering wheel)
My own LT4 has just under 90K miles and the only parts replacement I've had to do (not counting normal wear items like brakes) is the rear hub washers that were clicking. Other than that it's been only the standard fluid and filter changes: clutch and brake fluid, oil, gearbox and differential lubricants, etc.
I've had this C4 since 2002 and it's been the most reliable car I've ever owned...and I bought my first car in 1964.
A) Most people that aren't familiar with later C4's tend to think it is a lower power car. This makes it fun to see the look on their faces. (especially the c5 folks)
B) At least where I live, there seems to be less than a handful of c4's. The c5's and c6's are everywhere.
C) It's a great DD. Well mannered in traffic, reliable, and yet very fun to drive. The torque curve is almost flat so I can get that pushed in my seat feeling very easy any time I desire.
The only things I don't care for are the few rattles and leaks, but the car is twelve years old, so compared to any other twelve + y/o car it's probably less. (even less than some new cars). Also the gear rattle from the ZF6. But A,B,and C more than make up for these little inperfections.
The LT4 is fast and quick. I believe it is the best bang for the buck right now in the Corvette world. And with just a few $ in mods it could keep up w/ just about anything out there.
