Reassembling the steering column
Old Aug 12, 2008 | 06:41 PM
sgt0704's Avatar
sgt0704
7th Gear
Default Reassembling the steering column
i've done a search, but couldn't find the answer i was looking for.
i'm reassembling the steering column in my 84. it's got a tilt with the telescopic (moves in and out) wheel. the problem is getting that spring between the upper bearing, and the horn contact compressed.
i have a spring compressor... but there's a C clip that keeps everything tight, and keeps the telescopic part of the shaft from coming all the way out. but, i can't get the spring to compress, because the telescopic shaft keeps coming out... how do you get that shaft to stay in, inorder to compress the spring?
pics attached...
Tools/parts
shaft down
Shaft up
Old Aug 12, 2008 | 07:40 PM
JackDidley's Avatar
JackDidley
You have to put the telescoping lock back on and lock it down with that.
Old Aug 12, 2008 | 08:00 PM
Chris44m's Avatar
Chris44m
2021 C4 of the Year - Modified Finalist
i had a problem getting the C clip back in after i locked the wheel back down, i had my neighbor push it down, while i dropped the C clip back in.
C
Old Aug 12, 2008 | 08:04 PM
sgt0704's Avatar
sgt0704
7th Gear
how do you lock it down? the lock is in.. that C washer keeps it from coming out all the way... but i can't get that spring compressed enough to get that washer back in.
maybe you could elaborate.
Old Aug 12, 2008 | 08:11 PM
JackDidley's Avatar
JackDidley
its been a while. I think you have to put the phillips head screw back in, push the collumn down and tighten the screw.Then attach your tool.
Old Aug 12, 2008 | 08:32 PM
Chris44m's Avatar
Chris44m
All i can remember is pushing the shaft all the way down, putting the spring on, then the assembly, and while my buddy pushed hard on the assembly i slipped the C-clip on, it took a few times, its was hard to do, but not impossible.
Old Aug 13, 2008 | 12:17 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Your problem is because you have the wrong puller tool; you need the type for tele wheels that has a pin in the center to hold the tele rod down while you compress the sping in order to slip in the C-clip.
Old Aug 13, 2008 | 01:00 PM
sgt0704's Avatar
sgt0704
7th Gear
do you have a pic of said compressor?
i will check the local parts store later...
thanks for the help.
To Reassembling the steering column
