WHat does BLM stand for?
Old Aug 16, 2008 | 01:31 PM
Klondike's Avatar
Klondike
Default WHat does BLM stand for?
I'm trying to learn all the terminology and abbreviations used here. I tried to look up in the search and found pages on it, but when I click on any of the posts I get the message, "No Thread specified. If you followed a valid link, please notify the administrator". I guess they're still sorting out the history. Could one of you kindly tell me what a BLM is?
Old Aug 16, 2008 | 01:34 PM
MK 82's Avatar
MK 82
Block Learn Multiplier
http://www.gnttype.org/techarea/faq/BLMINT.html
Old Aug 16, 2008 | 02:03 PM
Klondike's Avatar
Klondike
Thanks. I gotta learn this computer stuff If I'm ever going to keep up!
Old Aug 16, 2008 | 02:19 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Not to be confused with a BLT. Sorry, I had to use up my allotment of wit for today, as you can tell I don't get a big allotment.
Old Aug 16, 2008 | 03:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
... If you followed a valid link, please notify the administrator".
I tried the Search function yesterday and it was FUBAR for me too...
The ECM uses the 15 BLM cells to store fuel injector pulse width trim values, with 128 being the neutral value, i.e. no trim applied to injector pulse width due to O2 sensor readings.
Each cell represents a different set of driving conditions such as throttle position, load, rpm, etc. Cell #1 represents base idle and cell #15 WOT operation, this latter cell has a permenant value of 128 where no correction is applied to injector pulse width.
Old Aug 16, 2008 | 06:13 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
I was told awhile back that the BLM whatever had to be changed because when I changed my injectors, the dash fuel mileage was 2 MPG off. Anyone know what that will set me back? It would be nice to have my dash mileage accurate again
Old Aug 16, 2008 | 07:14 PM
MK 82's Avatar
MK 82
You were told wrong.
Old Aug 17, 2008 | 08:10 AM
the blur's Avatar
the blur
I thought cell 0 was idle.
Old Aug 17, 2008 | 08:17 AM
JackDidley's Avatar
JackDidley
Injector constant may need to be changed if you have bigger injectors. If you do any mods to the motor, the mpg function will probably be off. Mine is pretty optimistic too.
To WHat does BLM stand for?
