Water pump
Old Aug 19, 2008 | 02:33 PM
jhammons01's Avatar
jhammons01
Originally Posted by corvettedan22
In that link the front of the motor is caked in oil, well it is on mine also.. Why is this ?!
Putty knife anyone?
that timing chain cover is leaking. Check those 10mm bolts. You'll find them all loose. Don't kill them tightening however, they are kinda small.
WD40 or some other solvent
Old Aug 19, 2008 | 09:09 PM
thecatmac's Avatar
thecatmac
I bought a new water pump at autozone, had it in a day. You should really change it, I doubt it's the 2 gaskets...........also make sure you put the heater hose on the pump before you put the ac back on, I forgot about that dam hose and had to rip it all apart again.....think, think, think.....
Old Aug 20, 2008 | 08:01 AM
kehler's Avatar
kehler
Originally Posted by 86PACER
Explain. Modified the timing cover?
right out of my FSM 6A1-14
5. Install cover-to-oil pan seal, lightly coat bottom of seal with engine oil, and position cover over crackshaft end.
6. Loosely install cover-to-block upper attaching screws.
7. Tighten screws alternately and evenly while pressing downward on the cover so that the dowels in the block are aligned with the corresponding holes in the cover. Position cover so that the dowels enter the holes in the cover without binding. Do not force cover over dowels so that the cover flange or holes are distorted.
8. Install remaining covers screws and torque to specifications
Old Aug 20, 2008 | 10:27 AM
Muffin's Avatar
Muffin
Thank you. After Fay last night I needed a laugh this AM. replacing a timing chain cover without dropping the pan is one small step removed from doing the heater core. Our FSM missed the target on this one.
Old Aug 21, 2008 | 01:47 AM
jhammons01's Avatar
jhammons01
Dan, have you given up?
Old Aug 21, 2008 | 08:41 AM
Demonic85's Avatar
Demonic85
The water pump was a piece of cake on my '85, the timing chain not so much. Half the work is removing all that emissions BS which i'd already removed from mine
Old Aug 22, 2008 | 12:50 AM
corvettedan22's Avatar
corvettedan22
Yes its all set. I probably can do the job in a bout 1 hour now that its fresh in my head!
I only had to take that a/c off about a million times to make things fit back to gether, fix problems , etc
My back is killin me but its done !
Old Aug 22, 2008 | 01:35 AM
proclaimer36's Avatar
proclaimer36
The only thing I can add is buy the water pump gaskets even though they come in the kit. the ones with the kit are made out of paper and suck. the single ones are made out of some composite material. Just my 2 cents.
Old Aug 22, 2008 | 09:30 AM
89er's Avatar
89er
not too bad a job, you might want to consider repalcing your timing chain while you're in there
At 47,500 miles the timing chain would be about the last thing I would touch.
It does not have a rubber belt that goes out every 60,000 miles.
Old Aug 22, 2008 | 09:56 AM
Demonic85's Avatar
Demonic85
no but the crappy stock ones have plastic teeth on the cam gear
Old Aug 22, 2008 | 11:08 AM
Iroc57's Avatar
Iroc57
Just do the water pump, at 47K miles I think that your timing chain will be OK
Everyone has an opinion and this is just mine
