Problems... at same time sadly
Old Aug 18, 2008 | 01:50 AM
McGirk94LT1's Avatar
McGirk94LT1
Default Problems... at same time sadly
Ok. so i have a good idea what it is anyway, but i have two problems. One is that my passenger window on my 94 is down, and now wont go up. SYS was flashing on my speedometer for about an hour, but now it doesnt come up but window still doesnt go up. My guess is the individual motor for that is shot. Also, i do mechanical but not electrical, anyone have any idea how many hours at a shop that would take? Also, i now have slight collant vapor coming through my vents, which im guessing... sadly... is a possible leak into my heater core? tons of smoke comes out when i jack the heat up but only a little when i have it on ac. Really am hoping its something else but whats anyones opinion on this? thanks in advance
Old Aug 18, 2008 | 01:58 AM
Binski's Avatar
Binski
I had the same window problem on my 93 LT1. It was the window switch, clean or replace and try it. I don't think it is related to sys light.
Old Aug 18, 2008 | 03:51 AM
Calderone's Avatar
Calderone
try hitting the door under the armrest while pressing the power windows button up.-
try that
Old Aug 20, 2008 | 06:11 PM
McGirk94LT1
thanks ill try that. hopin it wont be much of a big deal. Anybody have any idea on the coolant situation? My coolant reservoir is at the cold line if not below it after round half a days driving. I notice if i leave ac or heat on it doesn't blow out any visible amount of vapor. But when i check coolant level it definitely has dropped. Thanks for anyones advice.
Old Aug 20, 2008 | 07:27 PM
Shawn93PoloConv's Avatar
Shawn93PoloConv
You should be able to smell a sweet coolant smell -- but regardless it should not lose coolant at all. So you may have multiple issues. Last time I had a fog coming out of the vents it was due to a low freon problem with the A/C. Get a gauge at your auto parts place and check the pressure. Good luck!
To Problems... at same time sadly
