Drain holes at back window
Old Jan 2, 2002 | 03:23 PM
fdcaptain's Avatar
fdcaptain
Default Drain holes at back window
Whats everyone doing to get rid of the water that accumulates at the back window by the doors after washing? I have a syringe with a tube attached to it to remove the majority of it. What has been the experience with the drain hole kits as sold by Eckler's, Mid America and etc.
Old Jan 2, 2002 | 03:31 PM
Arisa's Avatar
Arisa
Default Re: Drain holes at back window (fdcaptain)
I use a straw. Suck it up & spit it out. My wife says :U but I figure I drink that same water from the kitchen faucet & the car is clean so what the hey.
Neal
Old Jan 2, 2002 | 03:56 PM
GRX's Avatar
GRX
I've heard pros and cons on the subject but for me, I would rather absorb the water with some paper towels than start to drill into the fiberglass.
Old Jan 2, 2002 | 04:47 PM
John Row's Avatar
John Row
I've heard 2 types of opinions:
1) Works great.
2) Don't know, don't want to drill my car.
Next time I spot one on sale, I'm going for it.
Cheers,
Old Jan 2, 2002 | 04:54 PM
bogus's Avatar
bogus
Default Re: Drain holes at back window (John Row)
I would be concerned about drilling at that area... that is a major junction of the b-pillar and the rear quarter... it takes no time to run a paper towel through there....
Old Jan 2, 2002 | 05:00 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
Default Re: Drain holes at back window (bogus)
Try a small can of air, like the ones used to blow dust out of computers. I just back my vette up down driveway. It's drains on it's own.
Old Jan 2, 2002 | 05:30 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
WHEN I INSTALLED MY NEW REAR WEATHERSTRIP I DIDNT GLUE IT IN ON THE BOTTOM. SO ALL I HAVE 2 DO IS LIFT IT UP & SWIPE A SHAMMY THROUGH THE AREA & IM DONE. STILL A PAIN BUT NO DRILLING! GOOD LUCK! :)
Old Jan 2, 2002 | 05:48 PM
The Example's Avatar
The Example
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Drain holes at back window (ConeKLR)
I just get up right behind it and blow. Works for me, takes all of 5 seconds.
Old Jan 2, 2002 | 08:12 PM
carter200's Avatar
carter200
Received the kit as a Christmas present and will be installing soon. That small a hole should not do anything bad if done right. :seeya
Old Jan 2, 2002 | 08:30 PM
Louis Bartay's Avatar
Louis Bartay
Hello,
How big is hole that you drill for the tube? :chevy :cheers:
Old Jan 2, 2002 | 09:42 PM
CowboyNVette's Avatar
CowboyNVette
Default Re: Drain holes at back window (Louis Bartay)
Hello,
1 of 119 :confused: well dang here is no 2 of 119
Old Jan 2, 2002 | 09:53 PM
RichS's Avatar
RichS
Default Re: Drain holes at back window (CowboyNVette)
I put them in my 95 and they worked great. I won't drill the same holes in the GS so I blow it out.
Old Jan 2, 2002 | 10:18 PM
Louis Bartay
Hi Boots,
Go figure. Does your Vette have the Beige interior too?
Nice Vette :chevy :cheers:
Old Jan 2, 2002 | 11:04 PM
MardiGrasMan's Avatar
MardiGrasMan
I use paper towels and lift up the glass cause I like to dry the entire weatherstrip & edge of the glass anyway. :smash: :smash: :smash:
Old Jan 2, 2002 | 11:42 PM
fdcaptain's Avatar
fdcaptain
Default Re: Drain holes at back window (yoslambo1@cs.com)
Good thinking with the weather stripping. It is a tight fit to get a towel in there. Sounds like we're all facing the same foe.
Old Jan 3, 2002 | 12:01 AM
Ramrod92's Avatar
Ramrod92
Just take your time and be carefull drilling. I'm pleased with mine. :yesnod:
Old Jan 3, 2002 | 12:17 AM
2HIP4U's Avatar
2HIP4U
I take two paper towels and roll them up
to the size of a cigar, then slip the roll
into the corner where the glass meets the
weather strip. The wick effect does the rest.
A few minutes later and the channel is dry.
:seeya
To Drain holes at back window
Old Jan 3, 2002 | 01:08 AM
bluevette87's Avatar
bluevette87
i use one of those blue bulbs that they use to clean out a babys nose(booger sucker for lack of a better name)works great :cheers:
Old Jan 3, 2002 | 05:35 AM
vetsvette's Avatar
vetsvette
Default Re: Drain holes at back window (bluevette87)
Turkey baster then wrap a towel around a credit card and run it all the way around.
Old Jan 3, 2002 | 02:47 PM
ToddAT's Avatar
ToddAT
I installed the drain tubes on mine, work really well. If you do it, just be careful drilling. :cool:
