1987-1990
Old Aug 27, 2008 | 01:45 PM
Bradhobbs's Avatar
Bradhobbs
3rd Gear
Default 1987-1990
I have a 1987-1990 (Unsure of the date since I have not purchased this vechicle yet) But I have a Corvette, and the engine has a rod knocking. I have a 1973 Oldsmobile 98 that has a 454 engine in, could I drop that engine into the Corvette? I also have a 350 engine could that work?
Old Aug 27, 2008 | 11:27 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
No. and yes the 350 block would work if you did some work to it. No was for the Big Block unless you want to rebuild the front end of the Vette. Cheaper to buy a running C4
Old Aug 28, 2008 | 12:23 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
If the Olds engine is like the Chevy 454, you can use it, but there are alot of mods, and it could be expensive. If the 350 has a one piece rear main seal, it will work no problem. If it is a two piece, you will need to change the flywheel/flexplate, and maybe the pan.
Old Aug 28, 2008 | 10:54 AM
Bradhobbs's Avatar
Bradhobbs
3rd Gear
Default 350 motor
The 350 motor would be coming from a 1979 GMC truck, do you think I would have any problems then what you guys think?
Engine is currently in running condition but needs some cleaning up.
And the reason for doing this is because I can get the corvette really cheap for about $800
Old Aug 28, 2008 | 11:21 AM
Calderone's Avatar
Calderone
i would rebuild the original engine with topnotch internals and everything
trying to save in engine stuff won't be good on the long run.-
try to get it for $ 500 and fix the original engine
Old Aug 28, 2008 | 11:55 AM
Bradhobbs's Avatar
Bradhobbs
3rd Gear
I would do that ... but I have already got them from $1,300 to $800 lol
Old Aug 28, 2008 | 11:58 AM
Calderone's Avatar
Calderone
i kinda suspected it.....well
go there,with $ 500 in hand
tell him,hey this is all i got,deal ?
if not,let it go....i think you can get it ...
trust me ,please do it and tell us how it went
To 1987-1990
By Michael S. Palmer | 2026-06-03 11:00:24
