Hello. In dire need of LEFT SIDE FENDER for my 1994/Black.
The 3 "slotted holes" that accept the hardware for the 3 Torx screws
has broken off over time. There's no way to re-fasten the panel. HELP!
Could you be more specific? I have no idea which holes you are talking about. Do you mean the front inner fender?
The small panel in front of the door on the drivers side that has 4 louvers/vents to access the battery on the '94's. It has a bolt at the bottom between the panel and frame (about 1/4" space for wrenching)— a top bolt & 3 Torx screws on the rear part of the fender well.
Whats the problem they are readily available new,used or aftermarket?
