Headlight bushing change...HELP!
Old Sep 2, 2008 | 06:21 PM
John88RedVette's Avatar
John88RedVette
Default Headlight bushing change...HELP!
Does anyone have a good written procedure (with pics would be helpful) to change the driver side headlight bushings? Thanks in advance! JOHN
Old Sep 2, 2008 | 06:43 PM
StealthLT4's Avatar
StealthLT4
http://forums.corvetteforum.com/show....php?t=1848666
Stickied in C4 Tech/Performance. I followed it to a T, except for my headlights not having the lower mounting bolts.
Old Sep 2, 2008 | 06:52 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Hope this might help, it worked for me!
http://www.corvettemagazine.com/2002...hts/light1.asp
This is better detail
http://home.comcast.net/~zrjuan/headlight.html
Old Sep 2, 2008 | 07:34 PM
John88RedVette
Thanks guys. I'll check it out.
Old Sep 2, 2008 | 08:43 PM
larry00's Avatar
larry00
When I did mine I had to use a Dremel to take a bit off the diameter of the bushings to get them to fit.
Wasn't in my instructions.
Only one of them I think.
Other than that it was straight up.
I put in the metal gears but my old ones were still ok .
Old Sep 2, 2008 | 10:04 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
Make sure you have 5/32 punch!
Old Sep 3, 2008 | 09:48 AM
Z51JEFF's Avatar
Z51JEFF
There is an excellent write up that I just used when I did mine.The guy that wrote goes by ZR-JUAN.Great pictures.I just did both,drop me a line if you need some help.Parts of the job are tricky.
Old Sep 3, 2008 | 10:07 AM
aminnich's Avatar
aminnich
Check out the C4 tech section on corvette-guru.com. There is an excellent step by step, with pictures, thread right there.
Old Sep 3, 2008 | 06:53 PM
FLY_LIFE's Avatar
FLY_LIFE
Is this to replace or repair? Wouldn't it be easier to just replace them? I paid $290 for a NOS pair and I just have to put them in ...
Old Sep 3, 2008 | 07:24 PM
Z51JEFF's Avatar
Z51JEFF
The bushings are junk,change them now and be done with it.What year are the motors for?
Old Sep 3, 2008 | 07:42 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
The bushing I bought where $5.00 set, and hour of my time per headlight, you do the math.
Old Sep 3, 2008 | 08:33 PM
FLY_LIFE's Avatar
FLY_LIFE
I'm not great at this sort of thing. I figured new ones are about $500 each from GM and $300 each on evilbay so $290 for a pair is a great deal. Trust me I'd rather pay $10 and I have plenty of time to waste!!!
Old Sep 4, 2008 | 10:18 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I bought my bushings at Home Depot for less than $3 for all six. Definitely don't get raped at the dealership on parts and labor by buying all-new headlight motor assemblies when all you have to do is replace the bushings. That's the epitome of The Corvette Tax!
Old Sep 4, 2008 | 02:33 PM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Take it easy, guys.
There are some people that just don't have the mechanical ability to tackle even the simplest of jobs concerning cars. Perhaps FLY_LIFE is one of those people.
I agree on the Vette tax....maybe he has the scratch to be able to afford it.
Old Sep 4, 2008 | 06:10 PM
ottawabarber's Avatar
ottawabarber
Recently I had to face the same thing. I asked on this forum and got great help and advice. I am NOT a mechanic, I cut hair for a living, but with the encouragement of the members here I ordered 2 sets of bushings from Zip ( was told wisely that if I am doing one headlight, I should do the other)
While I waited for the parts in the mail I looked at every thread and sticky I could find here. Searched Google and read various other articles about replacing the bushings, and printed out a small pile of documents with photo's.
A friend of mine helped me (extra hands were nice) and we had both headlights fixed in a few hours for $11.00 . They work perfect !!!
I was told, "it may be the cheapest fix I will ever have on my car" and they were right. I had to replace my clutch and slave cylndr and paid a mechanic to do that work ( WAY beyond my comfort level ) and paid $1000 in parts and labor. I just purchased a FSM for my 88, and at least now I can inform myself and pick my "battles" and decide which ones I feel comfortable doing, and which I will leave to the professionals. I know that I can take an asprin for a headache, but I can't do brain surgery. I am finding my own comfort level as I go along.
I find the wise and knowledgable members here on this forum to be the BEST, and I am deeply thankful for the time and explainations I read here daily. I read almost every post whether it applies to my car or not, because it MAY someday be an issue I might face.
If the bushings don't work, then try the motors, but for a few hours and $11.00 it is worth a try - at least it was for me.
Good luck, and AGAIN thanks to all the members who are patient with us "newbies"
Old Sep 6, 2008 | 11:28 PM
John88RedVette
Lights are now fixed! Thanks for all the help.
Old Sep 9, 2008 | 02:33 PM
onedef92's Avatar
onedef92
There now! Ain't you glad you didn't get raped at the stealership?
To Headlight bushing change...HELP!
Old Sep 10, 2008 | 11:11 PM
FLY_LIFE's Avatar
FLY_LIFE
They are for a 1990 and I'm not sure I have the tools to change the bushings which I would tackle but I'm reading 5/32 punch and dremel??? Not in my tool box!!!
Old Sep 11, 2008 | 09:15 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
St. Jude Donor '12
An 8penny nail and a piece of sandpaper will do in a pinch. Thats what I used on my old 88 when I did the bushings. Need to do my 92 this weekend, have a dremel now, probably pick up a punch tomorrow.
Old Sep 11, 2008 | 10:00 AM
ottawabarber
A tip I was given when I did mine was use an old drill bit backwards - worked perfect.
