Checking injectors
Old Sep 4, 2008 | 01:35 AM
cadillac531's Avatar
cadillac531
Default Checking injectors
Hello, I've got a '94 LT-1. Is there a way to check the injectors with an ohm-meter? What ohms should the good injectors pull?
Constantine
Old Sep 4, 2008 | 01:41 AM
Mekanic's Avatar
Mekanic
Old Sep 4, 2008 | 10:11 PM
cadillac531
Originally Posted by Mekanic
Great vid.....thanks so much.
Constantine
Old Sep 4, 2008 | 10:16 PM
Mekanic's Avatar
Mekanic
No problem at all my friend. Any other injector type stuff please feel free to ask
Old Sep 4, 2008 | 11:15 PM
jfb's Avatar
jfb
I don't know about 94's, but my 87 measure about 16 ohms. An ohmeter will only find gross faults and an injector coil with a turn to turn short cannot be found with an ohmeter. But that injector coil can easily be found with an impedance bridge which measures the inductance and the Q of the coil. I found a bad injector on my 87 with my impedance bridge, the ohmeter read the same as all the other injectors.
To Checking injectors
