Headlight Question
Old Sep 6, 2008 | 11:38 AM
BLU 4ME's Avatar
BLU 4ME
Default Headlight Question
What causes the headlight motor to spin even thought the headlight is in the up position on a 1988? Thanks
Old Sep 6, 2008 | 12:38 PM
floridamale's Avatar
floridamale
More then likely a bad gear or bushing time to replace them. If you unplug the motor dose it stop & which direction is it spinning in up or down.
Old Sep 6, 2008 | 01:53 PM
StealthLT4's Avatar
StealthLT4
Your bushings are mush.
Here's what you need (get 2, one for each headlight. Even if only one is acting up, the other is not far behind): http://ecklers.com/product.asp?pf_id=29304&dept_id=1476
And here's how to do the repair: http://forums.corvetteforum.com/show....php?t=1848666
I just did mine a few weeks ago, and it was a piece of cake. Maybe 45 minutes for the first light, 15 for the second.
Old Sep 6, 2008 | 04:31 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Most likely stripped gears. If it suits you, they can be locked in the up position until you get the gears and/or bushings replaced. Just a thought if money is tight.
Old Sep 6, 2008 | 07:14 PM
BLU 4ME's Avatar
BLU 4ME
Thanks for the responses. Will pull them both to fix
To Headlight Question
