interior lights problem
Old Sep 9, 2008 | 08:36 PM
proboo's Avatar
proboo
4th Gear
Default interior lights problem
the interior lights in my '92 stay on for at least 15 minutes before they finally go off. i don't know if there is a delay module in a '92 or not.
Old Sep 9, 2008 | 08:53 PM
Goldcylon's Avatar
Goldcylon
Yes there is that was for the radio however until the drivers door was opened. I assume your having this issue after you leave and lock the car correct? Check the two door light switches. There are known to stick and fail. Also the rear coupe hatch switch. Open one at a time and varify they function one at a time. Then look to make sure they make contact. The door switches can be adjusted. Good luck GC
Old Sep 9, 2008 | 10:08 PM
dlb435's Avatar
dlb435
Yes, there is a delay modual. Mine was giving me problems. Took days to find it. Took it out, looked at it, put it back in. No trouble since. Go figure.
Old Sep 10, 2008 | 11:31 AM
proboo's Avatar
proboo
4th Gear
where would this delay module be located on a '92.
To interior lights problem
