Starter motor wiring help
Old Sep 11, 2008 | 08:14 PM
1986_Yellow's Avatar
1986_Yellow
Default Starter motor wiring help
Hey there everyone,
I have a big problem that I can't resolve here and I am looking for some help. I recently took the engine and transmission out of my 86 coupe.
After putting them back in and beginning the re-assembly I have got to the point of installing the starter. Now my problem, I labeled everything as I unhooked things in preparation for removal of the engine. The only wires I have labeled for the starter are the two that go on the large stud on the solenoid. According to the electrical schematics in my reference manuals there should be three wires, the one from the iginition switch should be purple and fit on the small stud of the solenoid.
The purple ignition switch wire is unaccountted for, I can not find a single wire that isn't labeled or accounted for. I can't remember how the starter was wired when I took it apart so I can't say 100% that the wire was even there to begin with.
Does anyone know if the starter might have been wired in a different fashion then the manuals talk about? Does anyone have pictures of a started with the wiring installed?
Any help would be greatly appreciated. I have search high and low and can not find that wire so I am at a loss.
Thanks again for your time and I am sorry about the long questions.
Dave
Old Sep 11, 2008 | 08:22 PM
86PACER's Avatar
86PACER
It's got two big fat wires bolted down on the large nut, then on the small terminal it's the purple wire as the book states. That's all there is to it. The smaller wire comes out of the nearby wiring harness.
Mine is not even purple, because someone had replaced about 6 inches of it with a different color.
Old Sep 12, 2008 | 08:38 AM
vettezx-6's Avatar
vettezx-6
The wire going to the smaller terminal has to be there for the starter to work. It probably got tucked behind something and you're just not seeing it.
To Starter motor wiring help
