Power brake booster
Old Sep 17, 2008 | 08:07 PM
Bill Cude's Avatar
Bill Cude
Default Power brake booster
Question, my brake pedal will almost go to the stop at the bottom, I have changed the master cylinder, brake pads, no fluid loss any where I can find, fluid level is never low. I can't find a vacuum leak anywhere, do you think my problem is the brake booster?
Old Sep 17, 2008 | 08:12 PM
Eddywill's Avatar
Eddywill
Bill in my opinion you know you have booster issues when you have to stop your car with the muscles in your leg.
Old Sep 17, 2008 | 08:19 PM
takovr's Avatar
takovr
Default Crack
Check to see if you have a crack in it, that's what happened to me and I replaced the brake booster.
Old Sep 17, 2008 | 08:22 PM
92LRC's Avatar
92LRC
ditto.
It may not even have to be a crack. The diaphragm could be bad.
Old Sep 17, 2008 | 09:14 PM
Bill Cude's Avatar
Bill Cude
So if the booster is going bad, will the pedal travel almost to the floor?
Old Sep 17, 2008 | 10:18 PM
vetteblondie's Avatar
vetteblondie
Mine did, had to put all of me onto the brake pedal to stop it and it went to the floor like standing on concrete. Also, I'm no expert, however, my mechanic told me that when I stopped and the engine 'revved' just a tiny, tiny bit, that, along with the pedal issue, was a dead giveaway. Got mine replaced part and labor for around $250. Most places here don't charge just to look and see. Good luck.
Old Sep 17, 2008 | 11:27 PM
Lichen's Avatar
Lichen
Really doesn't sound like the booster. Sounds more like you have air trapped in the lines. Do a really good total bleed (buy speedbleeders).
Old Sep 18, 2008 | 12:10 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default brake booster
If your braking system is working, but your power booster is not you will still have full pedal. Extreemly hard to stop car this way. Sounds like you have air in the system somewhere. Just my $.02
Good luck.
Old Sep 18, 2008 | 10:17 AM
Bill Cude's Avatar
Bill Cude
I have a spare brake booster, think I will try that, and see if it makes any difference. Will let you know what I find out.
Old Sep 18, 2008 | 10:39 AM
ejscarfo's Avatar
ejscarfo
Good luck.
Try bleeding the brakes first and see what happens. Also, you mentioned you replaced the master cylinder, did you bench bleed that before you installed it?
Old Sep 18, 2008 | 05:54 PM
jmartynuska's Avatar
jmartynuska
Just replaced my booster this past weekend. Pedal was very, very hard to press but it did not go anywhere near the floor. Almost felt quite the opposite - pedal goes down farther with a functioning booster. Doesn't sound like a booster to me....
Old Sep 19, 2008 | 04:31 PM
Billy Stargazer's Avatar
Billy Stargazer
If I recall when my booster went bad I could hear the sound of air escaping whenever I depressed the brake pedal. I went with the steel replacement one rather than pay twice as much for the plastic one. As far as the installation went, it was not easy to move around down there but it only took a couple of hours to get it in. That has been over 3 years ago and it still works fine.
Old Sep 19, 2008 | 05:09 PM
81c3's Avatar
81c3
My question is did it have the same symptom before you changed the M/C and pads? If you didnt, then you have air in the lines as many have said. The symtom of a bad booster is a rock hard pedal, not a pedal that goes to the floor. I think at this point swapping the booster is a waste of time.
Old Sep 19, 2008 | 08:58 PM
CorvetteMike2024
Corvette Enthusiast
Default booster
Bill,
You are not fixing anything by changing your booster. BTW, let us know how much it sucks to change it out. I have changed many. But I would never change out a good one.
Evtreemly difficult to reach top bolts. Good Luck!
Corvette Mike
To Power brake booster
