Clutch slippage
Old Sep 18, 2008 | 07:16 PM
93c4matt's Avatar
93c4matt
Default Clutch slippage
My 93 is slipping very badly into every gear. I dont know if i need to replace the entire clutch assembly or just adjust the clutch. If someone has a guide on how to adjust my clutch, I have access to lifts and would do it with some help from a vette freak here in town. Any ideas guys?
Old Sep 18, 2008 | 09:41 PM
tbwstingray's Avatar
tbwstingray
sounds like ya might need a clutch
Old Sep 19, 2008 | 07:28 AM
Aaron71771's Avatar
Aaron71771
The clutch is self adjusting, if you have not already done so, make sure your clutch fluid is topped off.
Old Sep 19, 2008 | 08:28 AM
93c4matt's Avatar
93c4matt
Where do I go to check the clutch fluid?
Old Sep 19, 2008 | 12:07 PM
gigs94c4's Avatar
gigs94c4
sounds like time for a new clutch, the fluid is located under the ECM module against the firewall
Old Sep 23, 2008 | 01:13 AM
93c4matt's Avatar
93c4matt
Would low fluid really cause it to slip that badly?[
Old Sep 23, 2008 | 02:52 AM
Frizlefrak's Avatar
Frizlefrak
No.
Low fluid or air in the line might cause it to not disengage completely, but it won't cause slippage.
Stick a fork in it, it's done. Plan on a disc, pressure plate, and throwout bearing. Take a look at the flywheel surface as well.
Sorry....probably not what you wanted to hear.
Old Sep 23, 2008 | 02:54 AM
Frizlefrak's Avatar
Frizlefrak
To be clear;
Low fluid can cause it to grind when shifting gears, as the clutch may not be completely disengaging, but it won't cause slippage.
Old Sep 23, 2008 | 07:33 AM
78pacer's Avatar
78pacer
As a question....how much is a stock setup?
Mike
Old Sep 23, 2008 | 11:40 AM
93c4matt's Avatar
93c4matt
A stock replacement kit including the pilot and throwout bearing, clutch disk and pressure plate runs around $250 through most auto parts store. The quote I got on labor, not through the dealer, was around $370. So all said and done, its gonna be around $700 probably.
To Clutch slippage
