hard bumps
Old Sep 26, 2008 | 01:01 PM
my1stvett95's Avatar
my1stvett95
Default hard bumps
new to all this, trying to figure out what to look for, my 95 rear is lower on the drivers side, when i hit a bump I it feels like the back end is gonna fall off, I've replaced shock.. what else should i look for
Old Sep 26, 2008 | 04:41 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
The rear height is adjusted by way of a 10” long bolt that connects the top of each rear wheel hub assembly to the transverse spring. From the factory there is a castle nut/cotter pin at the bottom, or a Nylox nut if lowering bolts were installed. First check that the length of exposed thread is not significantly different left to right. If that’s OK, then it’s possible that either the top or bottom rubber bushings have fallen apart. These would be the two easy fixes. Good luck with it.
Old Sep 26, 2008 | 10:23 PM
RedVette84's Avatar
RedVette84
How much weight did the original owner weigh?
Old Sep 26, 2008 | 10:32 PM
Frizlefrak's Avatar
Frizlefrak
To hard bumps
