coolant please help me guys
Old Sep 26, 2008 | 09:25 PM
imdaking06's Avatar
imdaking06
Default coolant please help me guys
i am having a major problem the coolant in the coolant overflow tank is bubbiling up with the cap on. The tank starts to bubble near cap and starts to overflow with the cap on does the thermostat need to be changed? I KNOW for sure that i need a new coolant tank ?
Old Sep 26, 2008 | 09:33 PM
Zo3o6's Avatar
Zo3o6
How fast does it start to overheat? How old is the cap?
I would put a new cap on the surge tank, fill it with coolant, burp the system........ then see what you have. Thermostats dont fail that often.
Ron
Old Sep 26, 2008 | 09:43 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Burp the system as mentioned. If you don't know how to do it, then follow these instructions and have another person to help you do this as it takes two.
Take off the radiator cap and hold the car from 1800-2000 RPMs and add coolant as the level goes down and refill it until it is topped off. Regardless, you probably should flush the entire system, replace the resovoir and cap, and then purchase a new radiator cap as well. It might be the culprit to your problems and is inexpensive compared to engine damage from overheating.
Old Sep 26, 2008 | 11:02 PM
MK 82's Avatar
MK 82
It would be a big help if we knew what engine we are talking about.
Old Sep 26, 2008 | 11:08 PM
pt's Avatar
pt
Default coolant
Put a new cap on. I had the same problem. I bought a new cap from ecklers and the problem went away.
Old Sep 26, 2008 | 11:12 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default coolant
What motor? The symptoms can also be a blown head gasket. Bubbling in overflow tank.
Old Sep 27, 2008 | 09:11 AM
M.J.L.'s Avatar
M.J.L.
His avatar looks to be a 92 LT1 model vette. Hope the guy comes back soon and clarifies that up.
Old Sep 27, 2008 | 01:08 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
To coolant please help me guys
