89 build code location
Old Sep 30, 2008 | 09:15 AM
wheelhorse's Avatar
wheelhorse
Default 89 build code location
I just purchased a red 89 coupe with 9223 miles. I also have a 95 red coupe with 57000 miles. I'm addicted to the C4. I got the build code sheet from Bowling Green for the 95. The codes are also located in the rear compartment behind the drivers seat on the 95 but not the 89. does anyone know where the codes might be located on the 89. In the spare tire storage compartment maybe? Thanks
Old Sep 30, 2008 | 10:03 AM
MK 82's Avatar
MK 82
Usually under the console lid or one of the storage compts lids in the hatch area.
Old Sep 30, 2008 | 12:06 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Over top of the gas tank. If you look up at the tank from the front end of the spare tire carrier you can often see the build sheet sticking out from the top of the gas tank. Of course, you can order a copy of the OEM window sticker and the build sheet from the Corvette museum.
Old Sep 30, 2008 | 05:54 PM
wheelhorse's Avatar
wheelhorse
That's what I did with the 95. I believe Bowling Green is where the museum is. I'll most likely do the same for the 98. Get the laminated version!!
Old Sep 30, 2008 | 06:57 PM
c4cruiser's Avatar
c4cruiser
GM move the Service Parts Identification" decal between the two places between the C4 production run. My 87 and my old 92 had this sticker under the console lid.
If it's not under your lid, the chances are that some prior owner had replaced the lid. The rplacement lids from the accessory catalogs are one piece and include the metal frame and the top.
The decal cannot easily removed as the adhesive backing will tear away the paper material and the printing is usually destroyed.
The decal itself has a GM part number, but there is no way to have another decal reprinted with the correct RPO codes, the paint code and VIN.
The NCM can provide copies of the original window sticker and the build sheet. Linky
Old Oct 1, 2008 | 09:53 AM
wheelhorse's Avatar
wheelhorse
I will check the center console lid.
Old Oct 2, 2008 | 02:10 PM
wheelhorse's Avatar
wheelhorse
Opened the center console door and there they were. I got all the build info from the forum. Thanks for all your input.
To 89 build code location
