Horsepower
Old Oct 2, 2008 | 03:44 PM
flagmann's Avatar
flagmann
5th Gear
Default Horsepower
I want to purchase a 450 hp crate engine to install in my 85. I want it to appear stock. Tpi as came. Has anyone done this type of eng swap. What mods will have to be done ??
Old Oct 2, 2008 | 04:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
To keep the stock TPI siamese the intake base, details on my site. This is a (nearly) no cost mod, save for the price of some Dremel bits & sanding drums.
To inatall a modified TPI intake try the AS&M LT runners and Accel base. This mod will run around $1k or so but is a simple bolt-on.
You will of course need larger fuel injectors along with some serious exhaust work to enjoy the full benefit of that motor.
You "may" also need a stouter radiator unless you have the Z51 option.
