Opti-Spark Testing??
Old Oct 4, 2008 | 09:12 AM
Donne Trav's Avatar
Donne Trav
Default Opti-Spark Testing??
Are there any easy methods for testing the '94 Lt1 OPTI-SPARK. The
additions of a new FUEL PUMP & FUEL FILTER did little to solve my
problem. Will test injectors today. One thing that I did notice is that
when pressing SCHRADER VALVE to relieve pressure from system,
I didn't notice ANY gas spillage at all. NONE—ZERO. Anyway I am still
in need of plenty HELP from you all. MANY THANKS
Old Oct 4, 2008 | 11:40 AM
RogerZ06's Avatar
RogerZ06
If your car idles for more than 30 minutes and doesn't start missfiring your opti is ok
Old Oct 4, 2008 | 03:58 PM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
That isnt quite accurate for every car that has an opti.
Opti's do the strangest/different things when going bad.
Had a person driven my car they would of never known it had a bad opti on one day...but could tell on a different day.
Mine could be driven for a complete hour without acting up, it would idle perfect, drive ok as long as it wasnt romped on...then, with a changing of the gears it would run rough at times.
A person could take it out the very next day; let it get into closed loop, it would idle perfect, and get an occasional backfire or miss while driving.
My problems didnt happen until I was driving to get it dyno-tuned (of course ).
I replaced the injectors first thinking that was the problem...it ran great the first time out...then the next day the opti showed its ugliness.
I got a GM opti NIB from Ebay for $99....replaced it, and its back to normal...
GL
Jim
Old Oct 5, 2008 | 07:14 AM
Donne Trav's Avatar
Donne Trav
GL
Jim
Jim,
Thanks for this reply. I haven't experienced any "back-firing" yet. You
can just tell the engines NOT running as it should. I can "get down" on
it in 1st, 2nd, third and maybe fourth gear. BUT NOT in 5th—definitely,
not in 6th—terrible shakes & car sounds like its about to fall a part. In
my last THREAD, before installing a new FUEL FILTER, when activating
the SCHRADER VALVE, there was NO spillage of gas, or any sounds of
a "hiss" at all. Nothing—Zero. THE GAS CAP WAS ALREADY OFF THOUGH. Any thoughts, anybody? P.S. I haven't REALLY drive my ride
in going on 2 weeks. . I getting WITHDRAWAL symptoms .
Old Oct 5, 2008 | 12:00 PM
bobmic93's Avatar
bobmic93
Check the back side of plug wires that possibly would could be to close to header pipe or manifold. A wire could be fouling out on the pipe. Ask me how I know. The symtems you mention are the same I was having. Also some opti act up at high rpms. Hopefully thats not your issue.
Old Oct 6, 2008 | 11:41 AM
RogerZ06's Avatar
RogerZ06
GL
Jim
My car was driving fine, Then the car started shaking bad after I drove around for one hour. After that every time the car would warm up I would have miss.
I bet his opti, water pump and wires are probably stock.
To Opti-Spark Testing??
