Dark dash display
Old Oct 5, 2008 | 11:07 PM
cajuncorvette's Avatar
cajuncorvette
Default Dark dash display
My C4 has a bright dash display (speedometer side) and a somewhat dim side (RPM side). Is this a bulb issue? The graphics are correct and fully functional, just not as bright. Easy or difficult fix? Thanks!
Old Oct 5, 2008 | 11:29 PM
Master__Shake_'s Avatar
Master__Shake_
Try playing with either the dimmer **** or the dash fuse. Otherwise might be a cluster problem.
Old Oct 5, 2008 | 11:35 PM
convas's Avatar
convas
If one side is bright and the other side is dim sounds like a burnt out back light globe.
Old Oct 6, 2008 | 01:51 AM
Calderone's Avatar
Calderone
mine is reverse problem,dim speedometer,bright tach
Old Oct 7, 2008 | 08:21 PM
ALS 08's Avatar
ALS 08
Bulbs. There's like several of them in the cluster and when one goes bad you still get bleed over light from the good ones. Looks dim but not out. Had that problem also but on Fuel Level bars.
To Dark dash display
