- If you are jacking the car on the pinch seam jack points that run along the bottom of the doors, be sure to check that the jack does NOT touch the fuel lines on the passenger's side and the brake lines on the driver's side. The lines run just inside the jack point and it is possible to have a "dished" jack pad crimp or crush the brake/fuel lines.
If I am jacking up the front I always run the front tires up on a couple of 2 X 10's then I use my jack under the engine cradle....For the back
I fabricated a Jack-a-Vette fits under the pumpkin and between the exhaust pipes........My delima is where to put the Jack stands!!! Any suggestions???????????
I think the seam might bent if you use flat jacking surface, I think it was designed for the emergency jack that has a notch and uses more surface than just a seam.
I'm using ends of the X brace (convertible) just before it goes up to the bolts.
If you locate the jack just right, you can get 3 wheels off the ground at the same time...that's strong.
I jacked it up many times, both wheels, almost as high as it would go. That was with a 3 ton floor jack with the round flat piece at the top. No bending at all. It's much stronger than the x-brace. Last time I had the x-brace off I was able to bend the edges straight with a good pliers.
I'd trust a jack and stands any day, over most ramps. I use one or two extra sets of stands and leave the jack under for redundancy and added saftey.
