Still not lower
http://forums.corvetteforum.com/show...909&highlight=
Some suggested that it was due to my car having 62k miles and with typically only one person that the springs were worn on the driver's side. Makes sense.
So, per advice, I installed a lowering kit on the right side. I lowered the new rear bolt almost to the very bottom. The car then sat pretty even, with the left side still being about 3/8" lower. Not enough to bother me really.
I noticed today that the right side is back up to about where it was previously, maybe a little more than an inch higher than the left. What could be the cause of this? Should I replace the shocks? Could they have anything to do with it? Or should I replace the springs?
Come on Vette-heads, there's a lot of know how on this forum, help a guy out.
Also, with the the right side extended bolt almost to the stop, should that have lowered it substantially? The top of the tire is 3" for the fender arch. 3" my not sound like much, but it looks it to me.
Update, I had noticed this after arriving home. I just went out to messure again and the left side has settled a bit and there is now a 1/2" difference in the two sides. Is this due to the shocks?
A performance shop I was used to work at did a lot of suspension upgrades on cars and a new mechanic had just got done installing a complete moton suspension on a porsche. When we went to sit the car back on the ground it was considerably higher than factory. After messing with it for several hours we figured out he had tightened the suspension while the car was raised and therefore putting pre-load on the bushings and not allowing everything to move properly.
