Does anybody know of a way to remove the lens assembly on the right front park blinker without removing the bumper? the clip was broke and in an attemp to remove the assembly unit from car i unbolted the two bolts and now the assembly just floats around the bumper , I can't line up the two bolts to reinstall them, on the hinge side of assembly. also I know about the single wire from the distributor to unplug so I can set the timing and it should be by the brake booster but i'll be damn if I can find it ...
Reason: sign off
i have do both things ..-
are you talking about the housing with the foglights ?
if its the sidemarker (on the fender) just screw both bolts and push it.-
the bolts are harder to reach but you need a driveshaft tool sockets
i donno how are this called but they are flexable and you can work in angles .-
Today i did the timing,check for a tan wire with a black line
its the only one like that! its near the driver's side valve cover,wiper,master cylinder
its near that area,unplug it from the connector and that's it,you'll find it instantly
