85 c4
Old Oct 16, 2008 | 11:45 PM
bignbeefy's Avatar
bignbeefy
Cruising
Default 85 c4
Hi guys , i have an 85 tpi C4 , it was running beautiful going down the highway then all of the sudden it started to knock in the engine and i lost power. it has oil and great oil pressure. but when i rev it up i get knocking right above cyl 1 & 3 . any sudgestions?
thnx guys
Paul
Old Oct 17, 2008 | 12:19 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default knocking
sounds like the #1 or #3 rockers have loosened up or a pushrod screwed itself through the rocker. pull the rocker cover and look at what you have.
Do not drive it
Old Oct 17, 2008 | 11:08 PM
bignbeefy's Avatar
bignbeefy
Cruising
pulled it off and it all seems well checked both sides , seems like the knockin comming from near the fuel rail , i do have good oil pressure
Old Oct 18, 2008 | 08:15 AM
rons85's Avatar
rons85
Get a mechanics stethoscope (or use a long metal rod, like a long screwdriver) and "Listen" for the noise - this will help pinpoint the source - particularly if it's Outside the motor.
The Only thing that could be "knocking" near the fuel rail would be an injector. Normally you should be able to hear the injectors "clicking" - something loud enough to call a "knock" would be unusual, and Could be a dead injector - I suppose...
To 85 c4
