CD won't eject
Old Oct 28, 2008 | 02:44 AM
IndianLan's Avatar
IndianLan
Default CD won't eject
I pressed the eject button one day when I wanted to listen to the radio. Let the CD player retain the CD. It has not been able to eject that CD since. Any tricks of the trade?
Lan
Old Oct 28, 2008 | 04:45 AM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
Lan
Been there, done that. Disconnect the positive post on your battery, then wait a few, connect back up and it should eject. It did on mine.
Hope this helps.
Laura
Old Oct 28, 2008 | 05:33 AM
toptechx6's Avatar
toptechx6
http://www.doctordons.com/
Old Oct 28, 2008 | 06:21 AM
Aquaman92's Avatar
Aquaman92
If all else fails Dr Don's is the answer.
Old Oct 28, 2008 | 01:54 PM
TNT-in-a-Skirt's Avatar
TNT-in-a-Skirt
I have had this happen to me. If you can slide a strip of stiff paper in on top of the cd it will sometimes break the connection and the cd will slide out. I don't know why this works ... had someone show it to me once and it worked.
Old Oct 28, 2008 | 05:38 PM
grn envy's Avatar
grn envy
Cruise-In X Veteran
Easiest way is pull the fuse for the radio and put it back in. All will be fine again.
Old Oct 28, 2008 | 09:17 PM
seijack's Avatar
seijack
Press the eject button and hold it in....It worked a couple of times for me...you may need to try it a few times.
Old Oct 28, 2008 | 09:47 PM
Hen94's Avatar
Hen94
When the CD won't eject with the radio on, I turn off the radio and hold down the eject button. That usually works for me.
Old Oct 30, 2008 | 06:25 AM
akmedic70's Avatar
akmedic70
Cruising
Thanks for the question and the answers! I too, have a stuck CD...
Old Oct 31, 2008 | 12:19 PM
IndianLan's Avatar
IndianLan
Thanks for your help guys and gal...
IndianLan
To CD won't eject
