Replacement ECM
Old Oct 29, 2008 | 08:07 PM
lgaff's Avatar
lgaff
2022 Corvette of the Year Winner -- Modified
2021 C4 of the Year - Modified Winner
Default Replacement ECM
I am looking for a replacement ECM for a 93 LT-1. What is the best source?
LGAFF
92 ZR1
#234
Old Oct 29, 2008 | 08:15 PM
xlr8nflorida's Avatar
xlr8nflorida
LGAFF
92 ZR1
#234
You will laugh but probably ebay or rebuild your own?
Old Oct 29, 2008 | 11:59 PM
CE1's Avatar
CE1
I needed one for the 93 Z/28 in Jan. and none were available. The only recource was to get on waiting list for 3-4 months or have GM rebuild it in 10-14 days, choose the latter. Check with your Chevy dealer.
Old Oct 30, 2008 | 12:17 AM
jabez's Avatar
jabez
92/93 ECM are hard to get and expensive. I think the best solution is to get yours re-built.
Here is one if you need one quick.
http://cgi.ebay.com/ebaymotors/90-91...25104003r32670
Old Oct 30, 2008 | 09:11 AM
NEVRL8T's Avatar
NEVRL8T
Do the ZR-1's use the same ECM?
Old Oct 30, 2008 | 10:25 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
http://www.autocomputerexchange.com/...FQRhswodYx1P3w
http://www.cardone.com/English/Club/...cs/default.asp
Old Oct 30, 2008 | 12:05 PM
Jim Martley2's Avatar
Jim Martley2
Check out my old post on ECMs. http://forums.corvetteforum.com/show...&highlight=sia
Also check this For Sale Post. http://forums.corvetteforum.com/show...ht=92+computer
good luck
Jim
Old Oct 30, 2008 | 08:31 PM
jabez's Avatar
jabez
The ECMs will work but some other problem will arise. I stuck a ZR-1 in my 92 (non ZR-1) and it ran ok but the gauges were all over the place. I got a high idle and the speedometer was going up and down while at a stoplight. Had this going on for 3 weeks until I found the right ECM. Now every thing is back to normal. Sold the ZR-1 ECM on Ebay for 300.00.
Old Oct 31, 2008 | 08:10 AM
NEVRL8T's Avatar
NEVRL8T
Old Oct 31, 2008 | 11:27 AM
nickyg's Avatar
nickyg
I recently did mine. Go to pcmforless: http://www.pcmforless.com/
I dealt with Bryan Herter. Set a couple of custom parameters and the turn around time was great. I recommend to all.
Old Oct 31, 2008 | 06:06 PM
pipe's Avatar
pipe
You can buy a ECM from www.JimsPerformance.com he's in Ellicot City, Md. GM fuel injection guru. Pipe
To Replacement ECM
