Odd dash light problem when dark only
Old Nov 1, 2008 | 09:54 PM
Jims1988C4's Avatar
Jims1988C4
Default Odd dash light problem when dark only
When I put my headlights on when its dark,the dash goes out and is completely dark. I can barely see the gauges. when I shine a light in the dimmer sensor the lights come back on. If my headlights are off the dash works fine. I replaced my headlight motors awhile ago and never used my car at night because the headlights didnt work. IM not sure if it was like that before or not.What might be the problem ?? If I put my headlights up during the day or if its a bright cloudy day they work fine.
Old Nov 1, 2008 | 10:45 PM
LangstC4's Avatar
LangstC4
There is a light sensor in the dash that is supposed to dim the dash at night...could be defective. You can also try turning the headlight **** clockwise..At least in my 85 there is a dimmer.
Old Nov 1, 2008 | 11:07 PM
Blak Z06's Avatar
Blak Z06
Sounds like the problem.. But if you've ever owned a GM vehicle you know the dash dimmer is in this switch and you already checked that.. Right??
Old Nov 2, 2008 | 12:48 AM
jfb's Avatar
jfb
From the poster's forum name I gather he has an 88 (always leave no doubt and include the year vette you are asking help for), and the 88 has a dash dimmer control as part of the headlight switch. If you turn the headlight switch **** clockwise, you brighten the dash in the dark. Try it.
Old Nov 2, 2008 | 03:20 AM
BAM92's Avatar
BAM92
My 89 had this problem with the sensor on the light sensor on the left hand side of the dash. If, I put my finger over it, the dash would go dark.
Old Nov 2, 2008 | 09:51 AM
Jims1988C4's Avatar
Jims1988C4
Old Nov 2, 2008 | 09:53 AM
Jims1988C4's Avatar
Jims1988C4
"There is a light sensor in the dash that is supposed to dim the dash at night...could be defective" That sounds like the problem.
Old Nov 2, 2008 | 09:45 PM
jfb's Avatar
jfb
If the photocell were defective, then shining the flashlight on it wouldn't have an effect. Since the OP said he can brighten the lights with a flashlight on the photocell, the photocell is good.
Reading AND comprehension is fundemental.
Old Nov 2, 2008 | 09:52 PM
WALKINGGRUNT's Avatar
WALKINGGRUNT
try the fuse for the headlight switch, my mechanic did it for my 85 and it worked, hope this helps.
To Odd dash light problem when dark only
