slight noise when cold
Old Jan 14, 2002 | 10:04 PM
neekos's Avatar
neekos
Default slight noise when cold
Hey guys, maybe you could help with this. When the car is cold and I drive it and come to a stop, I can hear a slight clunk noise either coming from the rear or u-joints. Once it warms, the noise is no longer there. Any guesses as to what it may be? Other wise the car shifts perfectly fine.
Old Jan 14, 2002 | 10:10 PM
Rob90's Avatar
Rob90
Default Re: slight noise when cold (neekos)
Posi could be making some noise. Does it happen when going around corners? Mine makes noise every now and then
[Modified by Rob90, 8:12 PM 1/14/2002]
Old Jan 14, 2002 | 10:23 PM
neekos's Avatar
neekos
Default Re: slight noise when cold (Rob90)
No noise going around corners. Only time it does this is the first five minutes of driving. Then it drives fine.
Old Jan 14, 2002 | 10:34 PM
Rob90's Avatar
Rob90
Might try doing a search on Rear end noise. I bet it is just the posi making some noise until the lube gets warm.. Might try changing the lube in the rearend if not done recently
Old Jan 14, 2002 | 10:40 PM
neekos's Avatar
neekos
You're right. It wouldn't hurt to change the fluid even if it doesn't cure it.
Thanks.
Old Jan 17, 2002 | 04:30 PM
neekos's Avatar
neekos
Any more input or is this common ?
Old Jan 17, 2002 | 08:10 PM
neekos's Avatar
neekos
The noise is only when coming to a stop as the gears wind down to a standstill. Again, the noise is gone when warm. Does it sound like u-joint or the nrmal noise of a posi gearing down ?
To slight noise when cold
