"door ajar" switch
Old Jan 15, 2002 | 05:36 PM
FC2000's Avatar
FC2000
Default "door ajar" switch
MY '90 ZR-1 HAS A GOOFY DOOR AJAR SWITCH. IF I JUST TOUCH THE INTERIOR DOOR PANEL IT LIGHTS UP AND WILL STICK IN THE OPEN POSITION AND DRAIN THE BATTERY. ANY ONE ELSE EVER DEAL WITH SOMETHING LIKE THIS? IS THERE A SIMPLE WAY TO DISABLE THE SWITCH? [IMG][/IMG] :cry
Old Jan 15, 2002 | 06:18 PM
92VetteforU's Avatar
92VetteforU
Default Re: "door ajar" switch (FC2000)
I just had the door switch replaced in my 92. It started setting the alarm off all the time. Apparently the previous owner took out the door switch and tucked the wires inside the door. It was okay until the wires moved and shorted out, then I had the alarm problems.
Old Jan 15, 2002 | 06:19 PM
scorp508's Avatar
scorp508
Default Re: "door ajar" switch (92VetteforU)
Wait..... Is this the door ajar switch, or the door jam switch?
Old Jan 15, 2002 | 06:39 PM
FC2000's Avatar
FC2000
IT IS THE DOOR AJAR SWITCH FOR SURE.
I ASSUME THE DOOR PANEL HAS TO COME OFF TO GET TO IT.
Old Jan 15, 2002 | 06:40 PM
scorp508's Avatar
scorp508
Ok. I'm just wondering because the Door Ajar switch is not able to drain the battery unless it is a different setup in the late C4s. The door ajar switch/light only works when the keys are on. The door jam switch on the other hand will leave the interior lights on and drain ya. :)
Old Jan 15, 2002 | 06:45 PM
FC2000's Avatar
FC2000
IT MAY STILL BE THE "AJAR" SWITCH, WHEN I TOUCH THE DOOR PANEL THE AJAR LIGHT COMES ON AS WELL AS THE INTERIOR LITE. HOWEVER WHEN THE BATTERY WAS DRAINING I DID NOT NOTICE THE INTERIOR LITES ON. MAYBE I AHVE A PROBLEM WITH BOTH SWITCHES? [IMG][/IMG] :crazy:
Old Jan 15, 2002 | 08:42 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
You can change the switch without removing the panel.
I went nuts over this, turned out to be my rear hatch switch.
Until you get a chance to fix this, you can pull the fuses. There is a 5 amp and a 20 amp fuse. The 5 amp takes care of the door lights and under the dash and the 20 amp takes care of the hatch lights and radio.
It should be labeled on your fuse door.
Old Jan 15, 2002 | 11:34 PM
Admiral Fairway's Avatar
Admiral Fairway
To remove and replace the switch without removing the panel do the following:
Remove bottom screw and replace with a longer screw of the same size.
Remove the top screw, pull switch out as far as you can on longer screw.
Replace top screw behind switch. There is a plate inside the door that you
are trying to keep from falling inside the door, if it drops you will need to
pull the panel to get to it.
Remove bottom long screw and pull switch out to get to plug.
Reverse procedure to install new switch.
Old Jan 16, 2002 | 05:14 PM
FC2000's Avatar
FC2000
Default Re: "door ajar" switch (cnl3rd)
thanks for the advice!! if it ever warms up enough to actually work in the garage i'll follow your instructions!! [IMG][/IMG] :yesnod:
Old Jan 16, 2002 | 07:44 PM
jfb's Avatar
jfb
When is a door not a door ???
When its ajar.
Old Jan 16, 2002 | 08:22 PM
ZBRA's Avatar
ZBRA
Default Re: "door ajar" switch (jfb)
I replaced my driver side switch due to alarm problems. I pulled the panel to do it. Not that hard. That fixed the problem. :yesnod:
To "door ajar" switch
