code 36
Old Nov 30, 2008 | 04:31 PM
revival1's Avatar
revival1
Default code 36
I
Can anyone help. I'm getting a code 36 on my 1989 corvette. The wire clip at the maf air flow is broken but it looks like its on when I check it. Can I zip tie it or do I need a new end. Also would this cause the code?
Thanks in Advance,
Lori
Old Nov 30, 2008 | 05:12 PM
Bill Cude's Avatar
Bill Cude
Had the same code on mine a while back, turned out to be the MAF burnoff relay.But yeah, I would change the connector in it looks like it is not connected good. If it is the relay, they are right by the battery on the fire wall. Hope this helps.
Old Nov 30, 2008 | 06:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
-you can zip tie it
-it won't cause the code
Indeed replace the Burn-Off relay.
To code 36
