Bright Lights
Old Dec 6, 2008 | 01:15 PM
VetteDriven's Avatar
VetteDriven
Default Bright Lights
So when I pull back on my turn signal stalk the bright lights
dont come on. Whats wrong? Its a 1996.
Old Dec 7, 2008 | 08:11 PM
VetteDriven
Anyone had this problem? Bright lights not working?
Old Dec 7, 2008 | 11:01 PM
HANK AZ.'s Avatar
HANK AZ.
I just bought a 92 with the same problem. I thought I had a bad high/low switch. When I got it, for reason I pulled the lever back further to the steering wheel and they worked. I felt really dumb but I never had a car that I had to pull it that far back.
Old Dec 7, 2008 | 11:48 PM
GEAgent21's Avatar
GEAgent21
Default Light dimmer switch
Most of the time the switch is out of adjustment. The switch has elongated holes where the screws go. The screws get loose and the switch slides up where there is not enough travel in the stalk to make it switch from low to high. You will need to drop the steering column down to get to the switch unless your hands are a lot smaller than mine. It is not a big job. Drop the carpeted panel under the steering column. Take the two nuts off that hold the steering column up to the bottom of the dash. Pull down on the steering column. The switch is on top of the column and below the dash. Good luck.
To Bright Lights
