Crate Engine question?
Old Jan 17, 2002 | 09:40 AM
Vettman 1's Avatar
Vettman 1
Default Crate Engine question?
My '91 has 126K miles and the intake has a small coolant leak (6 hrs labor) I'm considering a GM crate engine replacement. Has anyone had the experience? ZZ3 perhaps? I'm in Ca. so I need to keep the smog legal, and use the same intake etc.
Regards, RB :confused:
Old Jan 17, 2002 | 12:57 PM
vader86's Avatar
vader86
Default Re: Crate Engine question? (Vettman 1)
do you want to modify the car, i.e. more HP, or do you just want something that will get you around with about the same power
Old Jan 17, 2002 | 04:53 PM
qkvette's Avatar
qkvette
we put the gm 300 Hp in my brother's 86 and he has no problem passing the
smog test. we just recently updated it to 1.6RR and 52mmTB. runs much better. he is scheduled for another smog test this month, so hopefully
the new mods didn't affect the emmisions that bad. . ( i think GM
replaced the zz3 motors w/ the zz4. check out the tech area of the forum, a guy posted some info about stroker kits (from chevyengines.com ;i think) pretty good prices too)
good luck
Old Jan 17, 2002 | 08:26 PM
1MoorTym's Avatar
1MoorTym
You might want to consider a partial block. You could get either the L98 replacement partial or a ZZ4 if you're going to need the extra beef on the lower end.
I bought the replacement partial for my 89, but then installed the ZZ4 valve train, CAM and other goodies along the way.
The crate engine had too many pieces I couldn't use to keep the emissions.
Old Jan 22, 2002 | 07:04 AM
Pete89's Avatar
Pete89
Default Re: Crate Engine question? (1MoorTym)
The zz4 is a good motor .The stock tpi intake is a big restiction and needs to be upgraded to get the power out of the zz4,headers will help it also
To Crate Engine question?
