Differential lube
Old Dec 15, 2008 | 04:08 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Default Differential lube
I just got a quote from a local GM dealer for $130 to change the lube They say the oil is $65 is that right? Anyone got links to cheaper oil and additive?
Old Dec 15, 2008 | 04:14 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
The dealer will steal your money. Lift the car, pump the oil and add gear oil in it.
Oil pump ($10)
Differencial additve for limited slip
2 qt of rear axle oil
teflon for differential plug
refer to the owners manual
You will pay max : $35~$50
Get teflon from Joe the Plummer (neighbor)
Old Dec 15, 2008 | 05:03 PM
96GS#007's Avatar
96GS#007
Oil pump ($10)
FWIW, I use Red Line 75W90, it has the limited slip additive included (ie you don't have to add it separately). Total cost for 2qts is ~$20 including tax.
Old Dec 15, 2008 | 05:28 PM
Aardwolf's Avatar
Aardwolf
That's what I do as well. I'm still using a pipe wrench on the plug.
Old Dec 15, 2008 | 05:33 PM
Redeasysport
Is Mobil1 GEAR OIL SYN 75W90 a good choice? Does anyone know if the additive is built in with it? What is the capacity of a D36?
I guess it does have the additive built in but is 2 qts enough?
http://www.mobil.com/USA-English/Lub..._LS_75W-90.asp
$10.89 a qt at Advance
Old Dec 15, 2008 | 08:10 PM
c4cruiser's Avatar
c4cruiser
The stock gear oil is a 80W-90 GL-5 rated fluid and not a synthetic. Add two bottles of the GM Posi additive. Gear should run $4-5 per quart and about $7 for a bottle of the additive.
Get one of the cheap transfer pumps from Harbor Freight and suck the oil out from the fill hole. Clean the pump and use it to put the fresh gear oil in. Takes about 2 quarts. Don't use teflon on the filler plug. The plug is steel and the housing is aluminum. Just use a good anti-seize on the plug threads.
Old Dec 15, 2008 | 08:21 PM
BluRay's Avatar
BluRay
I have become a REAL fan of the BG differential additive for posi and limited slip. It is a synthetic replacement for whale oil. The stuff really does make a difference(unlike 95% of additives).
Old Dec 15, 2008 | 08:38 PM
Redeasysport
Question still stands is this good to use?
Old Dec 15, 2008 | 08:53 PM
hill's Avatar
hill
Yes it is good that's what I use
Old Dec 15, 2008 | 10:01 PM
Aardwolf's Avatar
Aardwolf
Could try some Schaeffer's. http://www.bobistheoilguy.com/gearoiltest.htm
Here's some additive data: http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old Dec 15, 2008 | 11:26 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Why would you guys run synthetics when the engineers who designed the posi specifically say not to?
Old Dec 15, 2008 | 11:39 PM
Redeasysport
And do you have a link to that? I thought Mobile One was the best stuff to use. Is this question like which head is the best?
OK how about this stuff?
http://www.corvetteguys.com/royalpur...-gear-oil.html
Old Dec 15, 2008 | 11:57 PM
Redeasysport
More confusion
http://forums.corvetteforum.com/c5-g...you-use-2.html
64% in the poll use synth what does that say. Looking at Bob is the oil guy the synth does not flow very well Geeze I would like to get the best. 28% use GM and almost as many use Royal Purple of course those are C5 guys but is there a difference?
Old Dec 16, 2008 | 12:24 AM
Motsiv2's Avatar
Motsiv2
What is the capacity of the diff? Or, did somebody mention it and I missed it?
Old Dec 16, 2008 | 12:25 AM
Redeasysport
More info
Richmond Gears says to use Synth in their rebuilds
101 Corvette projects say to use Synth too.
Dam you Bob the oil guy why do I have to look at your stuff. It always makes me paranoid.
Old Dec 16, 2008 | 02:13 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
More info
I love Bob the oil guy, it tottally confuses me too.
Ask LPE, what do they use?
My Mobil 1 I used the GM additive as it made noises turning left and right. Mine was built by IKERDS all three times ( two broken D36's, and now my D44 with no leaks and AMSOIL)
Mobil Leaked 3 times.
I think TOM PIPER wrote about it a while ago.
Old Dec 16, 2008 | 07:51 AM
runner140*'s Avatar
runner140*
Do it yourself. Its a $25.00 job and 20 minutes. I used a pipe wrench to losen the plug. Pumping out the old and pumping in the new, got some in my hair, thats a lousy condictioner.
To Differential lube
Old Dec 16, 2008 | 07:57 AM
geogolf's Avatar
geogolf
Default oil
redline gets my vote, additive is already in it
Old Dec 16, 2008 | 08:34 AM
Aurora40's Avatar
Aurora40
I believe so. I believe it enough that this is what I run. I've heard you do not need the additive with this. But I put in a bottle anyway. Apparently you only need enough additive to quiet the diff, so if it isn't making noise you don't need it.
Where have you found this specific warning about running synthetic oil in the diff? What engineers told you this?
Old Dec 16, 2008 | 08:42 AM
TA's Avatar
TA
I'd like to see this also. While these cars may have came from the factory with conventional gear oil, I don't recall ever seeing anything that said not to use it.
