spring rate conversions
Old Dec 15, 2008 | 08:55 PM
ragged claws's Avatar
ragged claws
Default spring rate conversions
How do you convert spring rates given in N/mm to lbs/inch. My '89 coupe with its FE1 suspension has a spring rate of 93.1 N/mm and I need to know how that converts to lbs/inch so I can compare it to the VB&P Sport Plus Adjustable front spring which is rated at 575-900 lbs/inch.
Old Dec 15, 2008 | 10:36 PM
Aurora40's Avatar
Aurora40
1 lb(force) = 4.448 N
1 in = 25.4 mm
So 1 lb/in = 0.175 N/mm
93.1 N/mm = 532 lb/in
Old Dec 16, 2008 | 10:07 AM
ragged claws
1 in = 25.4 mm
Thanks. Just the info I was looking for.
To spring rate conversions
