C4 Alignment
Old Dec 18, 2008 | 01:17 PM
jrod954's Avatar
jrod954
Default C4 Alignment
Curious - Has anyone tried to align their vette and was successful?
What tools would be required?
Old Dec 18, 2008 | 01:54 PM
Relic's Avatar
Relic
$140 is the tool I used.
The shop did it just fine.
Old Dec 18, 2008 | 02:28 PM
StealthLT4's Avatar
StealthLT4
http://forums.corvetteforum.com/c4-g...alignment.html
http://forums.corvetteforum.com/c4-t...r-to-shop.html
http://forums.corvetteforum.com/c4-t...alignment.html
Hope that helps. Searched "DIY Alignment"
Old Dec 19, 2008 | 08:13 PM
96polovette's Avatar
96polovette
I know even a 96 uses 1970s alignment technology, it is done with shims. I had mine done last year.
Old Dec 19, 2008 | 10:28 PM
l98tpi's Avatar
l98tpi
Max G’s
If you have mechanical aptitude you could do the alignment, but you will need a caster/camber guage and several different hand tools. Also, If you don't have a 180 ft/lb capable toque wrench, take it to a professional shop. Here's a link that may help-
http://www.vettenet.org/align.html
Old Dec 20, 2008 | 12:31 AM
Churchkey's Avatar
Churchkey
The quickest & most accurate method to set the toe is with toe plates like we use on the oval track cars.
http://www.saferacer.com/longacre-to...?productid=486
Old Dec 20, 2008 | 08:37 AM
shadowman1's Avatar
shadowman1
Talk to some people in your area and find a shop that will take the time to do it right. I spent 2 hours to get the shims right in the front end correctly set here in my shop.
Old Dec 20, 2008 | 12:41 PM
c4cruiser's Avatar
c4cruiser
Take the car to a shop so they can do it properly. Because the rear also requires alignment, what you do to the front end can impact the alignment of the rear end.
A four-wheel alignment shouldn't run more than $75 to $125. Find a reputable shop that will do the work without trying to do a hard sell on things like shocks, tie rod ends, or ball joints. These pieces do have to be in good shape to get an accurate alignment, but a reputable shop will tell you what condition the parts are in and whether or not they should be replaced.
Stay away from the chain places like Sears, Firestone, or similar names. You might check with the local AAA office to see who they recommend for service.
Old Dec 20, 2008 | 05:22 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Return on investment for a professional alignment is huge - I was very pleased with my results earlier this year.
Old Dec 20, 2008 | 11:21 PM
kawijames's Avatar
kawijames
I just use the Hunter at work:biggrin
To C4 Alignment
