help - washer fluid doesn't work
Old Jan 17, 2002 | 09:22 PM
red1990's Avatar
red1990
Navigator
Default help - washer fluid doesn't work
My washer fluid has totally stopped working. Prior to that it barely came out ... just a few drops at a time, and only then if I held it in "spray" mode for quite a while. Unlike any other car I've owned where it sprays a steady stream. Yes, I've made sure there's fluid in the reservoir, the lines aren't frozen etc. I can hear the pump trying to pump.
2 questions:
1. How much fluid is supposed to come out with a normal functioning wiper fluid? (it comes out of the wiper arms)
2. Any suggestions where I should to start to look? I'm thinking something must be clogging the lines.
I have a 1990 6spd.
Thanks in advance.
Mike
Old Jan 17, 2002 | 10:51 PM
dt35th's Avatar
dt35th
Default Re: help - washer fluid doesn't work (red1990)
Try taking the line off as close to the tank as possible or off all together and see if it pumps fluid, if not pump is probably bad
Old Jan 18, 2002 | 12:48 AM
jeepie91's Avatar
jeepie91
A good stream of fluid comes out when it is working properly. Since you said it was working but coming out slow and now it stopped
I would say the pump part of the motor is not working. The pump is mounted on the bottom of the tank so if you had a bad hose
it should be pumping the fluid out on the floor. I changed the tank on mine, you can take the small fender behind the tire off
and take a look, I can't remember if the back part of the wheel well needs to come off to change it, maybe someone else can
verify that. Hope this helps, good luck.
Of course if the hose was blocked it would not come out, you can remove the hose from the pump and try it,
if nothing comes out with the hose removed then its the pump, if it does come out the hose is probably blocked.
[Modified by jeepie91, 10:52 PM 1/17/2002]
Old Jan 18, 2002 | 08:54 AM
phrogs's Avatar
phrogs
Veteran: Marine Corps
Default Re: help - washer fluid doesn't work (jeepie91)
My fluid wasent working when I bought my car all I had to do was remove the washer bottle I had some fungus growing in there, so it had to removed the pump and clean it all out and that fixed my problem..hahahaha :yesnod:
Old Jan 19, 2002 | 10:42 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Chech the pump.
To help - washer fluid doesn't work
