Power Window problems..I need some help
Old Jan 18, 2002 | 02:22 PM
CowboyNVette's Avatar
CowboyNVette
Default Power Window problems..I need some help
My passenger side power window will not work in the afternoons, but in the mornings it works. :crazy: Does anyone have any idea where to start looking for the problem?
Thanks in advance
Boots
Old Jan 18, 2002 | 02:40 PM
HTRK-1's Avatar
HTRK-1
Default Re: Power Window problems..I need some help (CowboyNVette)
That is very :crazy: . Does it work with one switch and not the other?
Old Jan 18, 2002 | 02:45 PM
CowboyNVette
Default Re: Power Window problems..I need some help (HTRK-1)
When the window works both switchs work it, when it quits neither one will work. :crazy:
Its been doing this the past 5 days in a row. This morning it worked :yesnod:
[Modified by CowboyNVette, 12:46 PM 1/18/2002]
Old Jan 18, 2002 | 04:16 PM
HTRK-1's Avatar
HTRK-1
The only thing you can do is start chasing wires when its not working. I don't have the wiring diagrams for my car yet, hopefully soon. Sounds like a possible intermittent ground. The switches have to have a common ground or power connection check there. Hopefully someone with service docs can chime in. Sorry I couldn't help more. Good luck.
Old Jan 18, 2002 | 04:36 PM
CowboyNVette
Hey thanks anyway, I have been scratching my head on this one. I was thinking it is heat related, since sitting outside all day it stops working...I wonder if there is a common relay to operates each window. :confused:
Old Jan 18, 2002 | 04:43 PM
dmalhi1's Avatar
dmalhi1
:lol: i think you should check for its hours of operation just so you know between what times you can use the windows hahaha maybe it has a late night pickup window option?? :jester
hmmm maybe you haven't been feeding it enough tabasco these past few days ? ;)
heh and now to seriously answer your question......... i got no clue :confused: ? but yeah go with the wiring routine maybe your switch is just messed up..... are you near the end of your warranty phase? :D thats when most things start to break :lol:
Old Jan 18, 2002 | 04:53 PM
CowboyNVette
Default Re: Power Window problems..I need some help (dmalhi1)
:lol: :lol: :lol: dmalhi1 when i saw your name I knew it was gonna be something about tabasco...you just send me your address and I will send you enough tabasco to keep you warm this winter.. :lol:
The good part about it that I never use the passenger side window but it aggrevates me knowing something doesn't work like it should. I am gonna fix that sucker this weekend if it kills me. :lol:
Old Jan 18, 2002 | 08:04 PM
CowboyNVette
Come on guys there must be some really smart electronic wizs here :yesnod: TTT
Old Jan 18, 2002 | 08:49 PM
Dualnic's Avatar
Dualnic
Cowboy i sent u the Wiring Diagram from my 94 Helms on PowerWindows..they should be somewhat or the same with the troubleshooting guide also attached......as i was looking....it seems maybe u have a ground loose and when the temp r somewhat cool....the contact......"contract" due to the cooler temp...and as the temps raise....the contact "expands"....leading u to a loose ground....just my thought.
[Modified by Dualnic, 7:04 PM 1/18/2002]
Old Jan 18, 2002 | 09:07 PM
CowboyNVette
Default Re: Power Window problems..I need some help (Dualnic)
Dualnic,
Thanks for the email, I just printed all that out and that makes it look easy :yesnod: The puzzling part is that it works sometimes and sometimes it doesn't . Now today we had a cool front come thru, but you probably already knew that since you are in Texas, and it worked this afternoon for the first time this week. I am gonna get on this in the morning and will let you know what i find..
Thanks again :cheers:
Old Jan 18, 2002 | 09:18 PM
Dualnic's Avatar
Dualnic
Your Welcome....i am still waiting for that "COOL" front to arrive....it is still in the lower 80's high 70's right now.....which is fine...going to take off the TOP and going cruiseing tonight..... :)
Then my hunch might be correct....since u r having "Cooler Temp" the contact r "contracted" right now.
Old Jan 18, 2002 | 09:27 PM
HTRK-1's Avatar
HTRK-1
Man, it must be nice to drive your car all year 'round. They're calling for 6-8" of snow tomorow here in wonderful York,PA. Figures, I just picked up my vette Monday and this would be the first full day I would get to drive it. You wouldn't have an extra room for rent would yah! :lol:
Old Jan 18, 2002 | 09:43 PM
Dualnic's Avatar
Dualnic
Yup 3 of them.... :lol:
Old Jan 19, 2002 | 01:05 AM
JasonL's Avatar
JasonL
Just went through this with a friend's C4. Sounds like it's the motor, especially since you mention the door switches either both work, or they both don't. :(
But before jumping that far, check the ground behind the driver's side sill panel carpet, just forward of the speaker. Wouldn't hurt to check the circuit breaker either (passenger side dashboard). Either would likely cause both windows to fail though.
You can also check to see if both window switches are properly applying 12V across the window motor, when you hit either switch. The wiring diagram/diagnostic chart you have probably covers this...
Also, this is not a sure bet, but check your dashboard volt gauge to see if it drops about 0.2V when you hit a window switch. This would mean the signal is likely getting to the motor but nothing is happening.
Hope that helps...
:cheers:
Old Jan 21, 2002 | 04:09 AM
Mr. CJ's Avatar
Mr. CJ
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Power Window problems..I need some help (JasonL)
Take the door panel off first, a whole lot of wires to mess with under there, may be an easy fix just by looking at it! Good luck.
Old Jan 21, 2002 | 09:05 AM
dmalhi1's Avatar
dmalhi1
[QUOTE :lol: :lol: :lol: dmalhi1 when i saw your name I knew it was gonna be something about tabasco...you just send me your address and I will send you enough tabasco to keep you warm this winter.. :lol:
[/QUOTE]
:lol: nah i am kinda favoring barbeque sauce lately ;)
Old Jan 21, 2002 | 04:20 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Don't know if this will help or not:
On my 88 the switches(plastic part) seem to be partialy seperated from the switch itself. When my window won't go up I jiggle the plastic part and it catches on the real switch and up it goes. I need new switches, your problem might be different but it wouldn't hurt. the switches are cheaper than the motor.
To Power Window problems..I need some help
