Headlight Adjustment
Old Dec 27, 2008 | 10:12 PM
papafrancisco's Avatar
papafrancisco
Default Headlight Adjustment
Just replaced headlights. Sure the beam location is not the same as the replaced lamps. Is there a procedure for aligning lamps?
Old Dec 27, 2008 | 11:54 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Park it about 25ft from a garage door and get them level. Take it around the block and see if the driverside is focused to the right of the road centerline and the pass side is focused to the left of the edge of the road. If not try a couple of turns and repeat.
Old Dec 28, 2008 | 09:21 AM
papafrancisco
Thanks for the reply. If I hear you correctly the center spot on the garage door should be ~30" inches above the ground and they should crisscross to the outer limits of the lane. Good stuff. Thanks
Old Dec 28, 2008 | 10:27 AM
Redeasysport
Not crisscross but sort of side by side near the center of your lane.
To Headlight Adjustment
