I need some help
Old Dec 28, 2008 | 09:06 PM
keglmg's Avatar
keglmg
2nd Gear
Default I need some help
Nice forum!!!
I found a 1988 C4 Corvette at a good price and the only problem is that the original owner took everything apart and left it that way. Working with my brother-in-law we were able to get the dash/IP area put back together. If anyone has pictures of the IP areas at different stages of assembly this would be appreciated.
I have two other small problems:
1) How does the Theft Deterrent Controller attach to below the RH side carpet trim plate? A picture would be nice.
2) Can anyone tell me where these brackets go? Again, a picture would be nice.
Old Dec 28, 2008 | 09:50 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
The two left ones are upper dash supports that go to the firewall under the dash pad. The two with the wire loom plastic brackets go on the engine. Can't remember off the top of my head where the others go.
Old Dec 28, 2008 | 10:15 PM
BluRay's Avatar
BluRay
Here is the best thing that I can offer you. You won't regret it even if you have an FSM this is searchable and updated.
www.alldatadiy.com
Old Dec 29, 2008 | 12:28 AM
Siveck's Avatar
Siveck
The theft module is mounted behind the breadloaf or passenger crash pad. It might be mounted with the two brackets shown on the upper right side of your picture.
Old Dec 30, 2008 | 10:29 AM
u c brother's Avatar
u c brother
I need to know the location of the third bracket.
To I need some help
