P K E Module...
Old Dec 29, 2008 | 12:42 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default P K E Module...
Gents,
My P K E was not working and I tought it was the antenna but, it is in good shape after I trouble shooted with the FSM. The transmiter worked so my final verdict is the module. It is located behind the CCM. To get there, ALL center console components have to be removed .
What would you do?
Go for it or use the key like 92 and before Vettes?
How much a PKE module costs? I looked in XBay and there were none for sale.
Old Dec 29, 2008 | 12:57 PM
toptechx6's Avatar
toptechx6
PN 10261112, $231.26 from GMPD plus shipping.
Old Dec 29, 2008 | 12:59 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Originally Posted by PLRX
Gents,
What would you do?
Considering what an annoyance the PKE is, constantly locking and unlocking the doors if you're working around the car with the fob in your pocket, I'd vote for letting it stay dormant and just use the key. The only thing I use my fob for is to open the rear hatch.
Old Dec 29, 2008 | 01:41 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Describe what steps you took to determine the transmitter worked. I had problems getting my new fob to program and found that the "turn off" step was were it failed the light did not flash. I got it though by holding the key in on turn off and having someone else bring the fob in range. It was losing contact at that point.Hope this helps.
Old Dec 29, 2008 | 01:47 PM
Redeasysport
That really is not a problem. I always hold the door lock button down till it cycles(locks and unlocks turns PKE off) when I work on it or take somewhere to get something done.
Old Dec 29, 2008 | 02:56 PM
PLRX's Avatar
PLRX
2017 C4 of Year
I used the FSM. The transmitter works, I used my 95 Vette to program it. It worked
Old Dec 29, 2008 | 02:57 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Thank You Very Much!!
Old Dec 29, 2008 | 02:59 PM
Redeasysport
OK then just wanted to know what step it failed.Sure I can get my FSM out but it might be usefull to others to know how you did it.
Old Dec 29, 2008 | 03:20 PM
PLRX's Avatar
PLRX
2017 C4 of Year
You need tools, a voltmeter, patience, beer, music and let the C4 love guide you....
All PKE components are hiding
Old Dec 29, 2008 | 03:23 PM
Weav's Vet's Avatar
Weav's Vet
From what you have posted that you have done to it so far it all looks first class. Why stop now....I'd go for it.
Old Dec 29, 2008 | 03:28 PM
Redeasysport
If it is any consolation it is not that hard to pull the center console stuff out just a little tedious.
Old Dec 29, 2008 | 04:31 PM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
So I take it you have done it then? I purchased a reciever to install, but have been procrastinating for fear I am going to screw something major up.
Laura
Old Dec 29, 2008 | 05:59 PM
Red Dwarf's Avatar
Red Dwarf
Laura
I have scans from the FSM for upper trim removal & PKE replacement.
If interested my e-mail is lsylvestri@sbcglobal.net
It isn't that difficult to get to. Just go slow & easy & label everything.
Old Dec 29, 2008 | 06:01 PM
Redeasysport
Laura
If it is the same reciever it is no biggie .If it is aftermarket check the audio section of the forum.
Old Dec 29, 2008 | 06:27 PM
dreamer2468
Nope, not aftermarket, bought it from a forum member, but from what I have been reading, its gonna be a pita to get to.
Laura
Old Dec 29, 2008 | 07:00 PM
Redeasysport
Laura
Got a FSM?
To P K E Module...
