Headliner
Any help would be appreciated!
Thanks,
Once it was out, I carefully took off the old headliner. Then I sprayed the headliner adhesive to the cardboard, and carefully put the new headliner on - make sure its nice and tight. As I rolled it over the edges, I used duct tape to hold it (since it would be out of sight).
After it dries on the cardboard, simply place the cardboard back into the top. My cardboard/headliner piece fit back in the top pretty tight, but just to be safe, I applied some velcro stips - again out of sight. Came out perfect.
One tip - when spraying the adhesive - make sure you do it in an area where there is no wind. That stuff can get messy if it starts flying!
Good luck!
Chris
1988 Chevrolet Corvette 35th Anniversary #1941/2050
1989 Pontiac Turbo Trans Am #760 (1950 miles)
1986 Pontiac Fiero GT V6/5-speed
1983 Delorean DMC-12
1986 Toyota Supra MKII
1985 Kawasaki Eliminator ZL900
I have a link to the thread about it in my signature.
I couldn't get to a layer where it wasn't still crumbling, so I figured it had to be replaced thinking whatever new adhesive would just lose adhesion as the padding continued to deteriorate. So...
I took my fiberglass targa to a local upholstery shop that does hot-rods and boats.
He stripped all the old padding out down to the fiberglass and installed new padding and headliner material for $150.
Call me crazy.
Its just that easy.
