water pump
Old Jan 20, 2002 | 12:51 AM
8URVIPER's Avatar
8URVIPER
Default water pump
well today i walked out side to wash the vette :yesnod: then i saw a big spots of water :confused: then i was like WTF, so i called my friend jason to have him help me work on it. the stupid part was only $29 :yesnod: So we took the vette to his days house, which he ownes atlease 10 vettes in the past 10 years. so we started to work on it. OMG to take that little pump out was a pain :mad . the book made it sound so easy but nothing was easy. well ill take it back it was easy all the was to pulling off the water pump. then it toon us 2 hrs to remove it. 1 bolt :mad :mad . WE couldnt see it right under the pully and was in a tight spot. well atlease we did it and fix it :)
But we forgot to tighten the fuel lines :jester :nono: BUT we fixed that after we smelled gas and it was pooring everywhere. thank god it didnt blow up me. :cheers: well i had to share this with you all.
steven
Old Jan 20, 2002 | 12:59 AM
JonM's Avatar
JonM
Default Re: water pump (8URVIPER)
Congradulations..Feels good, doesn't it? :cool:
Old Jan 20, 2002 | 01:31 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers:
Old Jan 20, 2002 | 01:36 AM
Vic'89's Avatar
Vic'89
The water pump is a fun project. ;)
Vic
Old Jan 20, 2002 | 02:14 AM
Blue85L98's Avatar
Blue85L98
Cruise-In III Veteran
Congratulations...I recently replaced my water pump also...only because it had to come off to replace the timing chain & gears. I didn't know how old it was, and I thought it would be better to replace it while I was in there, than to have to pull everything apart again later. :cheers:
Old Jan 20, 2002 | 02:25 AM
GlockLT4's Avatar
GlockLT4
Default Re: water pump (mackeyred96)
:cheers: The joy of working on your car (and it working) is great! :cheers: :cheers: :cheers:
Old Jan 20, 2002 | 02:34 AM
CorvetteCoupe93's Avatar
CorvetteCoupe93
:cheers: congratulations
Old Jan 20, 2002 | 05:23 PM
8URVIPER's Avatar
8URVIPER
Default Re: water pump (CorvetteCoupe93)
ITS STILL LEAKING :mad :mad :mad NOW I AM :mad
Old Jan 20, 2002 | 07:11 PM
dmalhi1's Avatar
dmalhi1
:lol: yer car doesn't like you cuz you never did a photo shoot with it and your gf lounging around on it in a nice bikini for all your corvette forum brethern to gawk at :D
actually even if ya do that i bet it'll still leak umm.... hmm is there a hose or something that might need replacing?? :confused:
[Modified by dmalhi1, 3:11 PM 1/20/2002]
Old Jan 20, 2002 | 11:18 PM
CG77VETTE's Avatar
CG77VETTE
You should try a pressure test of your cooling system. I thought my water pump was leaking and it turned out to be a short "U" shaped bypass hose right in front of the throttle body. The coolant was leaking down the front of the engine giving the appearance that the pump was the culprit. Worth a shot to check the hoses.
[Modified by CG77VETTE, 9:18 PM 1/20/2002]
[Modified by CG77VETTE, 9:19 PM 1/20/2002]
Old Jan 20, 2002 | 11:55 PM
89 Bob L's Avatar
89 Bob L
Nothing is ever easy on these cars :yesnod:
Old Jan 21, 2002 | 09:11 AM
vette87's Avatar
vette87
Default Re: water pump (CG77VETTE)
Beware "the pressure test" if it leaks alittle now, it'l leak alot after. :yesnod:
Old Jan 22, 2002 | 12:13 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VIII Veteran
Good thing you didn't have to mess with an Opti! :eek:
Old Jan 22, 2002 | 04:47 PM
RadPolo96's Avatar
RadPolo96
Yeah, the pump is a pain... :cheers:
Old Jan 22, 2002 | 10:30 PM
8URVIPER's Avatar
8URVIPER
its not leaking now..... :mad comeon it cant just pick the days it wants to leak. we ran every test on it and it was fine. no leaks as of today :)
Old Jan 22, 2002 | 11:36 PM
pablocruise's Avatar
pablocruise
Possibly it's from bad cosmic reverberations from not using spellcheck on forum posts. :jester Sorry bro, couldn't resist. But seriously, what I did on mine was to bypass that bypass hose(I did this mod). One less hose to worry about now. :cheers:
To water pump
