87 ABS telltale
Old Jan 9, 2009 | 01:51 PM
Steve59's Avatar
Steve59
Default 87 ABS telltale
When I bought the car this summer, I was told that the ABS light was on because a pump was needed. Since the weather has turned cold here in PA. the light has not come on. Any thoughts as to why? Could this be a wheel sensor? an easy/cheap fix?
thanks
Old Jan 9, 2009 | 02:46 PM
GEAgent21's Avatar
GEAgent21
Default Abs
It could be anything but on mine the codes said L/R Wheel sensor. So I bought one ($130) and installed it. Same problem. I finally after 2 years bought a pinout tester and determined that the module was toast. Bought module, pump, valves, lines on ebay for $75.00. I only installed the module and that fixed the problem. So I sold the rest of the ABS assembly for $75.00. I still have a good L/R ABS sensor if you need one.
Old Jan 10, 2009 | 11:35 AM
Steve59's Avatar
Steve59
thanks for the info.....btw you must have been the guy I was bidding against......
To 87 ABS telltale
