C4 Tips and Tricks
Old Jan 16, 2009 | 08:05 AM
lostnfoundC4's Avatar
lostnfoundC4
Originally Posted by runner140*
Like these:
Now there's a nice clean and cheap back up hood release
I like it
Old Jan 16, 2009 | 12:25 PM
samh's Avatar
samh
Originally Posted by janarvae
Or you can use some small nuts. It worked perfectly on mine that was full of DexCool sediment. I didn't even have to use soap (and I was afraid of leaving soap behind).
Ice cubes worked great for me!
Old Jan 16, 2009 | 07:41 PM
Corvette505's Avatar
Corvette505
PASSING EMISSIONS
Bring it in on a low tank of gas (1-2 gallons) and add a quart or two or rubbing alcohol (at least 80% alcohol, the greater the concentrate the better) right before the test. This should lower your emissions by 20-40%. Since rubbing alcohol has water in it (hence the reason to go with the strongest alcohol content) immediately drive your baby to a gas station afterwards and fill-er up.
Old Jan 16, 2009 | 08:32 PM
chuck13's Avatar
chuck13
i would never have thought of that!fantastic idea!
Old Jan 16, 2009 | 10:47 PM
glenn87's Avatar
glenn87
All great ideas and I have used several of these while starting work on my 87 couple. This is my first vette after wanting one for several years and now in my fifties I finally got it. I wanted a c4 and fully understood that it needed work. You have all helped in making this a fun project so far. After being a mechanic for over thirty years even this is real experience and hopefully plan to due all the work myself. Keep the ideas coming because I have used several of them. Thanks again.
Old Jan 17, 2009 | 08:47 AM
Paul Workman's Avatar
Paul Workman
Default C-Beam plates
If you haven't already got 'em, they are well worth the money - if nothing else it makes either removing or reinstalling the C-beam a snap!
P.
Old Jan 17, 2009 | 09:33 AM
Steve59's Avatar
Steve59
Over the years the rugs in my 59 built up dirt and "grease" marks from me and various mechanics getting in and out. I wanted to clean them up but not smear the grease and make it worse. Since I do the dishes at home, I decided to try Dove liquid dish washing detergent. I was absolutely amazed at how clean the rugs came with not effect on the color (red). Quick easy and cheap. No smear, no nothing, the grease literally disappeared and the rugs look brand new. I used a fairly concentrated amount and had to spend some time "rinsing" the rug to get the soap out. Next time I'll try a more diluted mix. Ended up doing the rugs in my 87 also.
Old Jan 18, 2009 | 07:26 AM
Nick DL's Avatar
Nick DL
Thanks for the tips. Things like this are informative for someone like me who just bought their first vette. Thanks
Old Jan 20, 2009 | 08:37 AM
Corvette505
Great tips, one and all!
Old Jan 20, 2009 | 08:45 AM
TANGSODOMAN's Avatar
TANGSODOMAN
From: Somewhere in Ohio.....When the Zombies come head to Tang's house...
TIRE INFLATION
Keeping my tires over inflated when car is not going to be driven for a while has worked for me
