My First Post... Cruise Control Question???
Old Jan 16, 2009 | 10:16 AM
av8ersteve's Avatar
av8ersteve
6th Gear
Default My First Post... Cruise Control Question???
Hello all. After half of my life spent dreaming of having a Corvette, I finaly own one. 96 C4, LT4 6 speed manual with 64,000 miles on her; I'm in heaven . All is well with my new investment except for one thing, the cruise control does not work. I have checked the fues but thats not the problem so I'm hopeing someone here can help. Any advice will be greatly appreciated and thank you in advance.
Old Jan 16, 2009 | 02:35 PM
BobRR3's Avatar
BobRR3
The easiest thing to check first is the three way vacuum check. It's located on the right side of the engine coming off the intake manifold. One line goes into the dash for Air Conditioner control and the other line goes to the Cruise control valve.
Try that first
Old Jan 16, 2009 | 02:36 PM
BobRR3's Avatar
BobRR3
Forgot to say...You have to remove the right side fuel rail cover to see it...
Old Jan 16, 2009 | 02:40 PM
CVAN68's Avatar
CVAN68
On my '93, the cable is not connected to the cruise control over the battery.
Old Jan 16, 2009 | 02:57 PM
aminnich's Avatar
aminnich
There are two vac hoses to the sevo (0ver the battery). One supplies constant vac to the servo to suck the cable in. The other goes to a switch on the brake pedal. When the pedal is depressed the switch opens and the servo loses vac, thus disengaging the cruise control. Might be a 3rd switch on a manual, not sure about that part, mine is an A4.
Congrats on the new ride!!!!
Old Jan 16, 2009 | 03:56 PM
av8ersteve's Avatar
av8ersteve
6th Gear
Thanks for the info. I'll be checking all of that as soon as it warms up outside. 18 degrees right now, just to cold to play with my new baby.
Old Jan 16, 2009 | 04:23 PM
92LRC's Avatar
92LRC
take the time to fill out your profile and welcome to the forum.
Old Jan 16, 2009 | 05:01 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum..
Old Jan 16, 2009 | 05:34 PM
American Raven's Avatar
American Raven
C3 Corvette Enthusiast
I hve sorta the same problem - my cruise works sometimes, sometimes it doesn't. Sometimes it'll be locked on a speed then mysteriously disengage.
I have a new vaccuum valve and remanufactured servo unit sitting on my workbench. I may change them out next week.
Any other suggestions to this problem?
Old Jan 17, 2009 | 02:40 AM
Weav's Vet's Avatar
Weav's Vet
Try that first
Mine cruise was a little jerky when using the switch to increase speed. I replaced this and it fixed it right up. Good luck and welcome.
Old Jan 17, 2009 | 03:02 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
I guess i'll add my input in here. The little plastic thing on the right side of the engine was broken on my car.
I found out because my air wasn't working. But that thing is pretty fragile if you ask me so i'd check there first as it's very easy to spot if that's a potential problem.
Old Jan 17, 2009 | 05:04 PM
black1993's Avatar
black1993
Would like to jump in here also. I have a similiar problem. My cruise does not work either. The previous owner replaced the battery and there is a small plastic vacuum line that broke. I can not seem to see where it gets connected back to.
ALSO my vents in the car is stuck in the defrost mode. I am hoping the plastic line goes to the dash and that will solve at least one if not two of my problems
To My First Post... Cruise Control Question???
