Formula 88 degreaser
Old Jan 16, 2009 | 04:21 PM
92LRC's Avatar
92LRC
Default Formula 88 degreaser
Anybody use Formula 88 degreaser on their engine bay? I had a leak from one of my valve covers and I need to clean up.
Results, good bad?
Before you post about watching out for the Opti, I know. Water's not going anywhere near the opti.
Old Jan 16, 2009 | 11:06 PM
Vette Fast's Avatar
Vette Fast
Do your self a favor and use straight “Simple Green” and a lot of rags and an old tooth brush. It may take a little more time but the results will be well worth it. You will not have to worry about anything under the hood getting it’s finish stripped.
Use “Mothers Aluminum Polish” on all of the aluminum parts under the hood. You will be ready for the car shows in no time.
Old Mar 3, 2009 | 06:29 AM
samsonb's Avatar
samsonb
I've heard of Simple Green damaging aluminum.
Old Mar 3, 2009 | 07:09 AM
corvette95's Avatar
corvette95
simple green is the ONLY cleaner to use. IT will NOT hurt the suspension fiberglass like ALL the others. It will NOT repeat NOT hurt the aluminum... I heard the same things several years agao... contacted the company ..they actually called me. It has something to do with a 24 hour submurge issue on combat aluminum on fighter planes in the military... Gordon Killebrew uses SG..thats good enough for me...anything else will ruin leaf springs. Simple green will need a little elbow grease to get the stuff stuff though.
Old Mar 3, 2009 | 07:10 AM
corvette95's Avatar
corvette95
Only pertains to military issues on 24 hour submerge test on combat plane aluminum parts.
Old Mar 8, 2009 | 06:02 AM
samsonb's Avatar
samsonb
I've read of people here having their aluminum stained using "green" Simple green. Just do a google search.
To Formula 88 degreaser
