water pump
Old Jan 17, 2009 | 10:52 AM
v8s10Dan's Avatar
v8s10Dan
Default water pump
Does anyone know if a 1989 c4 5.7L was the reverse flow water pump with the serp belt or the v belts?
Old Jan 17, 2009 | 11:03 AM
Iroc57's Avatar
Iroc57
I pulled apart my 91' and it was reverse. Don't take this the wrong way but all you have to do is look at the thing
Old Jan 17, 2009 | 01:59 PM
v8s10Dan's Avatar
v8s10Dan
Default water pump
I guess the question should be do all serpentine belt set ups use the reverse rotation water pump, I hate to sound stupid but I am not sure what or where to look, long story short, I did some work on a late 70s Monte carlo and the owner brought a water pump for it, that was not his problem and left the water pump for me, will it work on my 85 with serpentine set up?
Old Jan 17, 2009 | 10:06 PM
GKK's Avatar
GKK
The Monte Carlo water pump won't fit your 89 Vette because the Monte Carlo water pump has a Long impeller shaft housing and the Vette uses the Short impeller shaft housing.
Also, the Monte Carlo water pump is Standard Rotation using a V-belt pulley designed for a 305 cubic inch V8 engine and is physically smaller than the C4 water pump.
Old Jan 18, 2009 | 08:31 PM
v8s10Dan's Avatar
v8s10Dan
Default water pump
Thanks GKK
To water pump
