Hydrolock help
Old Jan 28, 2009 | 02:19 PM
v8s10Dan's Avatar
v8s10Dan
Default Hydrolock help
Hey guys I was having a hydrolock issue and thought I had it figured out that is was bad injectors because it was only doing it on two cylinders #6 & 7 and its a batch fire system 85 TPI with a 1227730 ecm after installing another set of injectors I got from beerman, it still does the same thing, what else can it be ? The computer?
Old Jan 28, 2009 | 02:22 PM
JackDidley's Avatar
JackDidley
Take the vacuum line off the FP regulator. If it has gas in it its the problem.
Old Jan 28, 2009 | 02:40 PM
v8s10Dan's Avatar
v8s10Dan
Default Hydrolock
Yes sir Jackdidly gas came pouring out
To Hydrolock help
